<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: notstock71</div><div class="ubbcode-body">This is a little upsetting. Seller said he removed them from his 71 Nova to put Cal Tracs on.
Thanks for the help. </div></div> They will work on your Nova..the spring pad perch are basically universal and those bolt holes are grooved out for several different u-bolt diameters. |
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: whitetop</div><div class="ubbcode-body"><div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: notstock71</div><div class="ubbcode-body">This is a little upsetting. Seller said he removed them from his 71 Nova to put Cal Tracs on.
Thanks for the help. </div></div> They will work on your Nova..the spring pad perch are basically universal and those bolt holes are grooved out for several different u-bolt diameters. </div></div> Thanks for making what appeared to be a bad situation a good one. Now I'm torn, do I cut the extension off to make them as they were or do I leave them as is since they are supposed to hit right at the spring eye. Opinions on color? |
