Old 10-17-2013, 01:12 AM
Ryan1969Chevelle's Avatar
Default Re: The New, Newer Project Part Tres...
The new/proper/original valance looks so much better than the steel/proper/warranty unit.
Ryan
Old 10-17-2013, 02:03 AM
njsteve njsteve is online now
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: 67 442</div><div class="ubbcode-body">Just a suggestion in the spring I would take the valance off and leave it i the sun every once in a while and let it weather up a bit to match the fenders. The valance look a touch whiter than the fenders but that could be my monitor. Excellent job on making it fit so well and the paint looks real good. </div></div>
It's probably your monitor. [img]<<GRAEMLIN_URL>>/grin.gif[/img] The valance paint is much closer than the photos indicate. There are so many off angles and curves that a photo of the two panels at the same angle is almost impossible. The nose/bumper itself, is a noticeably different color than the fenders, hood, and valance, but that is the way they built them, so I don't want to mess with the patina.
Keep in mnd, also, that the polyethylene valances not painted when installed at the factory. They were molded in a variety of colors and were way off from the actual car color. So a bad mismatch would actually be more correct then a perfect paint match.
Old 10-17-2013, 02:43 AM
67 442 67 442 is online now
&quot;Keep in mnd, also, that the polyethylene valances not painted when installed at the factory. They were molded in a variety of colors and were way off from the actual car color. So a bad mismatch would actually be more correct then a perfect paint match.&quot;
I did not know that, great info to have tucked away.
When can we expect a book on all of the info you have on theses birds?
Old 10-17-2013, 11:31 AM
When I retire!
While it was originally designed as a wire insulating material in WWII, polyethylene was such a new &quot;Space Age&quot; material in 1972-3, that they couldn't find a paint that would stick to it. So they molded them in body color as an alternative. It is still a very difficult process. For example, try spray painting a red or blue Solo beer cup and see if the paint sticks for long. [img]<<GRAEMLIN_URL>>/grin.gif[/img]
Old 10-18-2013, 12:45 AM
It just occurred to me while looking out in the garage that I have seen this car's face somewhere before:
Is this one of those &quot;separated at birth&quot; photos?
Old 10-20-2013, 09:52 PM
OK, here is today's conundrum: I was looking at the hood latch assembly and it appears that the grommet that the hood cable goes through is partially broken (lower locating tab is broken off) and has been for a long while. The cable is actually sawing its way through the bracket. It also appears that the grommet that the pull handle passes through has a broken piece as well. Does anyone have the grommets? It appears that they may be the same grommet for both the upper cable guide and the lower handle guide.
Old 10-20-2013, 10:59 PM
I believe the GM part number is 488442, in case anyone has a couple of them sitting around. Knowing Gm there have to be other applications for this grommet.
Old 10-21-2013, 09:09 PM
Through the graciousness of PerformanceYears member 70Steve from down-under in Australia, a mint copy of the Sept/Oct 1990 issue of MUSCLECARS of the 60's/70's arrived today.
(BTW, the yellow hemicuda ragtop on the cover was my old car that I sold to Otis Chandler in 1987 - very weird coincidence that they are in the same magazine!)
Here it is:
Old 10-22-2013, 01:32 AM
Cool!
Old 10-22-2013, 09:59 AM
That is so cool, your old car and your new car in the same magazine....
Ryan
