Old 10-26-2013, 04:40 PM
kwhizz kwhizz is offline
Default Re: Next Years Power Tour Car Part 2
Another one of those little things that get stuck in the back of your head that you know will become a problem downstream because it's going too smooth just popped up........Now that I'm going to pull the engine for the last time (Hopefully) and tie up some loose ends......I decided to go back and check the tie rod to oil pan clearance that everyone else has "Issues" with....I didn't have any ......I had a slight contact in one direction but plenty of clearance when turning the other direction.....so....I noticed the center drag link wasn't centered with the engine and I thought I could get away with adjusting the tie rod ends to get everything centered and have clearance...........so.......I check everything again today and notice that the rotors didn't look like they were turning far enough.......so I start thinking about the turning radius not being sharp enough which would then shorten the drag link travel from side to side..........So.....I check to see where the steering arm stops contact the lower control arm..........Hummm!!.......I measure the Ridetech contact point and it's approx. 2 1/4" from the stop surface to the center of the ball joint..........I get out my stock lower arm and measure it at 1 1/2" ....Hummmmm!!!!.......I'll call Ridetech on Monday.....Better to deal with it now than after the engine is plugged in and all the accessories are on...........Maybe I'm making a mountain out of a molehill again...........
Old 10-26-2013, 07:55 PM
L-79 Nova L-79 Nova is offline
Ken, do you ever SLEEP? Ron.....
Old 10-27-2013, 06:59 AM
jannes_z-28's Avatar
jannes_z-28 jannes_z-28 is offline
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: kwhizz</div><div class="ubbcode-body">Maybe I'm making a mountain out of a molehill again........... </div></div>
It's better to be safe than sorry...
Jan Suhr
Stockholm, Sweden
1969 Camaro Z/28 ProTouring
My Car My Book My Photos
Old 10-29-2013, 12:40 AM
Well.......The day started out with me calling Ridetech and asking about the steering stops hitting way before the stock position and this was taking away from the turn radius of the car (again.....from the ball joint C/L to the stop surface on the lower control arm........Stock GM is 1 1/2&quot;.........Ridetech 2 1/4 inches.........)I sent pictures as requested and haven't heard anything since............I need to get this resolved so I can modify the pan for drag link clearance if req'd.........
The next issue was the trans cross member.........It seems that when the previous owners added the Turbo 400 trans they did the Hillbilly cut and weld to make it fit......so after looking and figuring out what to do with it.......I decided to make it bolt into the stock frame location and holes......and it ended up that the rubber trans mount ended up right in the middle of the crossmember...........so we made a new detail and cut and welded it together.....brought it home and it fell into place........then..........the new Wilwood Master cylinder showed up.....I knew the old one had some issues ( cause I are Smart)........opened up the new one , Bench bled it for a half hour .........not a hint of air and it seemed this one has more flow to the rear chamber.....so.....I knew this was gonna be easy..........Stick it on the car , bleed the fronts....no problem.......go to do the rear.........Same thing........no pedal drop while bleeding and just a few drops of fluid out of the bleeder and No clamping pressure at all on the rear rotors.........Darn!!!..........Time to start breaking the new lines apart and look for a restriction somewhere...........(a smart person would have probably done that B4 buying a new Master).......I also got the new Holley Pan Baffle assy that was recommended.......
Old 10-29-2013, 01:02 AM
I also changed my mind on the wheels I ordered.......Final Pick.....LOL
Old 10-29-2013, 04:14 AM
CC Rider's Avatar
CC Rider CC Rider is offline
Nice crossmember mod Ken! [img]<<GRAEMLIN_URL>>/biggthumpup.gif[/img]
Rick
1966 Chevy Caprice 427-390
2012 Chevy Camaro RS Convertible]
Old 10-29-2013, 10:57 AM
Ryan1969Chevelle's Avatar
The welds look like MIG for the braces to hold the cross member in place and TIG to modify the cross member, your shop must be very well set up.
Ryan
Old 10-29-2013, 02:01 PM
SS427's Avatar
SS427 SS427 is offline
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Ryan1969Chevelle</div><div class="ubbcode-body"> your shop must be very well set up.
Ryan </div></div>
Ha! You should see his shop and machinery..... Spoiled brat!
Rick Nelson
Old 10-29-2013, 04:24 PM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: SS427</div><div class="ubbcode-body"><div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Ryan1969Chevelle</div><div class="ubbcode-body"> your shop must be very well set up.
Ryan </div></div>
Ha! You should see his shop and machinery..... Spoiled brat! </div></div>
But I can't bench bleed a stupid master cylinder...........Darn!!!
Old 10-29-2013, 04:54 PM
ktownkid ktownkid is offline
All the tools in the world are not any good......without a skilled craftsman. You are a skilled craftsman, master cylinder not withstanding.............
ktownkid [img]<<GRAEMLIN_URL>>/beers.gif[/img]
Baseball, Hot Dogs, Apple Pie and Chevrolet
