Old 10-26-2013, 11:07 PM
BARRY BARRY is offline
Default rad
hi can any one tell me what this rad is code XF THANKS
Barry Allan
Old 10-27-2013, 04:07 AM
Kurt S Kurt S is online now
Default Re: rad
I can only tell you that I know it was used in a 1970 Olds 98. Part # 3017166, right?
Kurt S - CRG
Old 10-27-2013, 01:59 PM
Default Re: rad
it has rad tanks like a Camaro fire bird it is a 4 core rad know a 2 row rad I got it with a parts trade
Barry Allan
Old 10-27-2013, 03:38 PM
Default Re: rad
What's all the info on the tag?
Kurt S - CRG
Old 10-27-2013, 07:25 PM
Default Re: rad
no tag
Barry Allan
Old 10-28-2013, 08:57 AM
Default Re: rad
Can you be clearer? What is stamped XF? A tank? Then what's on the other tank??
Kurt S - CRG
Old 11-08-2013, 06:29 PM
Default Re: rad
Barry Allan
Old 11-09-2013, 04:10 PM
68z28kk 68z28kk is offline
Default Re: rad
Your XF tank is pretty common after 1970 and was used on the Camaro as well as Chevelle and other A body makes. The IL tank was common on the big block Camaros from '67 to '69. Yours appears to have F body brackets and I haven't found an example of any F body using that combination of tanks. These XF tanks are used on 2 3 and 4 core radiators. The XF was used on some 442s in '68 but the IL in conjunction with the XF tank is not shown in any documents that I have found. The IF is usually installed with the XF. If you could show better pictures of the top rail and the mounting brackets, that might narrow it closer to a specific year. The core width from tank to tank would narrow it to small block or big block. Clint
Old 11-10-2013, 02:29 PM
Default Re: rad
23 inch
Barry Allan
