Old 11-09-2013, 04:10 PM
68z28kk 68z28kk is offline
Default Re: rad
Your XF tank is pretty common after 1970 and was used on the Camaro as well as Chevelle and other A body makes. The IL tank was common on the big block Camaros from '67 to '69. Yours appears to have F body brackets and I haven't found an example of any F body using that combination of tanks. These XF tanks are used on 2 3 and 4 core radiators. The XF was used on some 442s in '68 but the IL in conjunction with the XF tank is not shown in any documents that I have found. The IF is usually installed with the XF. If you could show better pictures of the top rail and the mounting brackets, that might narrow it closer to a specific year. The core width from tank to tank would narrow it to small block or big block. Clint
