Old 11-25-2013, 01:28 AM
ALLZS ALLZS is online now
Default MUNCIE FILL PLUG
the fill plug in my 69 Muncie 4 speed is frozen in the case I cant get it to come loose any suggestions on how to get it out with out damaging the case
Old 11-25-2013, 01:49 AM
69 Post Sedan's Avatar
Default Re: MUNCIE FILL PLUG
Heat it up and melt wax into the threads.
Kurt
1968 Schwinn Orange Krate
1969 Schwinn Pea Picker
1968 Schwinn 5-Speed
1970 Schwinn 3-Speed Deluxe
1973 Schwinn 5-Speed Suburban
All Original Paint Bikes
Old 11-25-2013, 03:06 AM
The wax trick is a good one. Is the trans in the car or out? It is assembled or apart for rebuild? I have more experience with aluminum intake fittings which are a pain due to corrosion, etc. A trans plug should be similar. If intake plugs/fittings are tough I drill and cut them out.
Jason
Old 11-25-2013, 12:12 PM
THE TRANS IS IN A RUNNING CAR IT LOOKS LIKE SOMEONE HAS TRYED SEVERAL TIMES TO REMOVE THE SQUARE HEAD IS WELL ROUNED OFF DO YOU HEAT THE PLUG OR THE CASE ALSO WHAT TYPE OF WAX DO YOU USE
Old 11-25-2013, 12:46 PM
69PACE's Avatar
69PACE 69PACE is offline
you can buy a chunk of paraffin wax at the grocery store in the canning supplies section or at any craft store.
1969 Z11 L48 4 Speed
Old 11-25-2013, 02:02 PM
luv2sixty9 luv2sixty9 is online now
Use a large pipe wrench for leverage and it will come out. I had the same problem last week with a Muncie trans.
67 Z/28 Butternut Yellow
69 Z/28 Rally Green
69 Z11 Pace Car
2010 2SS RS Aqua Blue
68 Z/28 Lemans Blue
C7 Corvette
68 SS Lemans Blue
Old 11-25-2013, 02:15 PM
jasonL78 jasonL78 is offline
If the square nut is rounded and you can't get a pipe wrench on it. Weld a rod or small piece of flat stock steel onto the filler head. Use this for leverage to remove the filler plug. The little heat from the weld will help loosen it. You will need to buy a new drain plug anyway.
Looking for the next project.
Old 11-25-2013, 06:26 PM
marxjunk marxjunk is offline
buy a large nut that the plug head fits in, mig it in center just take your time get a good weld, wait a minute, and 2 things happen, you get real heat on it and then you can get a boxed end on it, it will back right out. Ive done it on the floor, but a rack makes it less miserable..and it works...
Mark
Old 12-01-2013, 12:22 AM
Joe69Camaro Joe69Camaro is offline
Usually the Hex head Is rounded off around the Bottom and not the top. There are 2 kinds of sockets that can be used in that case..
Turbo Sockets , and 8 pt sockets.
They All are best used when the trans is warm after a drive.
Rust grows on the steel or cast plug in the aluminum case thru condensation and expands stronger than lock -tite ..
Drilling both plugs are the best option in the end
If none of the others do it for you...
Never tried the Wax route..
Tubbed 69 camaro
Old 12-01-2013, 10:34 AM
TDW TDW is offline
I'ved used the wax on steam heater fittings that are a hundred years old with good results. The best wax that I've found for this is a "plumbers candle".
Tony
55 Nomad Gasser
70 SS 427 Nova
34 Ford Sedan..Hemi powered
Michigan/ Florida
