Old 11-26-2013, 12:46 AM
70 Forest Green Zee's Avatar
Default Re: Next Years Power Tour Car Part 2
Good job &quot;Fabrication Guy&quot; [img]<<GRAEMLIN_URL>>/worship.gif[/img]
1970Camaro Z28
Old 11-26-2013, 01:34 AM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Canuck</div><div class="ubbcode-body">Not much left of the original crossmember!!! Its all original except fot the right part, the left part and some of the middle! </div></div>
What Paul said! Wow!!!
Old 11-26-2013, 03:35 AM
CC Rider's Avatar
CC Rider CC Rider is offline
Trick Cross-Member Guy!
Rick
1966 Chevy Caprice 427-390
Old 11-26-2013, 01:26 PM
SS427's Avatar
SS427 SS427 is offline
Nice looking brake lines Ken as well as everything else on the car. [img]<<GRAEMLIN_URL>>/biggthumpup.gif[/img]
Rick Nelson
Old 11-27-2013, 11:12 PM
kwhizz kwhizz is offline
Expect the unexpected..........LOL..........By not being able to use the stock Camaro exhaust manifolds......I had to buy Headers.......The Headers didn't fit as advertised.......so we had to make things fit to the Headers.....then the Headers ran into the trans cross member........fix that........then I go to install the spark plug wires......the Boots hit the tubes.....new spark plug wires.........(two sets.....the first set I ordered didn't fit either)......The MSD wires had a bendable Boot and worked perfectly............
I also ordered a Vaporworx fuel pump control unit....instead of the pump running full speed all the time and having to use a Corvette Filter regulator.......this system monitors the fuel pressure and only feeds enough Voltage to the pump to satisfy the demand that the engine requires......hence.....no return line to the tank......I have been waiting for this unit to show up so I could install the wiring harness to the pump on the tank for installation........so......I also got some 1&quot; dia electrical shrink tubing and installed it on the gas tank straps and then heated them up and shrunk them on.......Pretty Neat .......almost &quot;Spiffy&quot;.......LOL..........Got the tank ready to go in but it was time for a Nap..........I'll get the tank in tomorrow after all the kids leave.............Happy Thanksgiving to all!!!!
Old 11-28-2013, 02:22 AM
IM RARE IM RARE is offline
you know the saying for every action there is a reaction especially when working and modifying stuff on a car LOL
Old 11-29-2013, 07:58 PM
I finally got the Gas tank installed.........would have been a lot simpler if they would have supplied bolts for the straps that were 1/2&quot; longer........Just couldn't get the nuts started........went and got some longer ones today and 5 minutes later it was in.....I also have the fuel line installed and completed........I also got the drive by wire gas pedal installed.......As long as I have the room while waiting for the new radiator to show up I'm going to get the intercooler pump and lines all run..........need to find a reservoir for the system........
Old 11-29-2013, 09:25 PM
good job &quot;gas tank guy&quot;
1970Camaro Z28
Old 12-02-2013, 10:36 PM
The new radiator showed up today.......Designed for LS engines.....Both hoses on the passenger side, cross flow and a fitting for the steam lines welded to the top tank.......Too easy....Got it installed and dug out the fan mounting brackets I made a while back and test fit everything........I love it when a plan finally comes together and works out........Ding!!!.....Ding!!!!!
Old 12-02-2013, 11:18 PM
NICE!! [img]<<GRAEMLIN_URL>>/headbang.gif[/img]
