Old 11-28-2013, 01:41 PM
Tracker1's Avatar
Tracker1 Tracker1 is offline
Default Paint testing for originality
Can paint be tested to determine originality? So can a sample be taken from a door jamb and be sent somewhere to determine if it is the original factory-applied GM paint from 1969?
thanks
Old 11-28-2013, 02:28 PM
Default Re: Paint testing for originality
I don't know that you can age date the paint. It should be laquer. Most repaints back in the day were either synthetic enamel, or later acrylic enamel. Repair work/blending was usually done in laquer. Door jambs most times didn't get repainted on a complete spray unless it was a color change.
You can wipe some thinner on a rag across an area of that jamb and see if the paint comes off. If it does, it's most likley laquer, and would point to being original,
FWIW
Old 12-03-2013, 01:27 AM
TechNova TechNova is offline
Usually an experienced eye can tell.
Take it to a body shop that has been around for a while. they know what to look for.
Old 12-07-2013, 02:55 PM
miket1 miket1 is offline
Send a message via ICQ to miket1
Original factory paint is a very thin layer compared to most, but not all, repainted cars, check the thickness of the paint first to get an idea.
69 Z28 Burgandy
