Old 01-07-2014, 02:36 PM
luzl78 luzl78 is offline
Default Re: ? on 1967 Camaro old drag car.
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: plumL78</div><div class="ubbcode-body">So does your L78 car have a special paint code. </div></div>it's a 4n car.
Old 01-10-2014, 12:45 AM
67rs/ss 67rs/ss is online now
This car is a 4N car.
But yes my L78 has a O-O paint code dark green metallic.
I have not had a chance to measure the the drive shaft yet hope
hopefully I can do it this weekend.
67 RS/SS L48 ERMINE WHITE
67 RS/SS L35 BOLERO RED
67 RS/SS L35 BUTTERNUT YELLOW
67 RS/SS L78 0-0
Old 01-10-2014, 01:22 AM
Sorry Kerry, just noticed that you were asking about his other big block.
Old 01-10-2014, 06:19 AM
jannes_z-28's Avatar
jannes_z-28 jannes_z-28 is offline
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: PeteLeathersac</div><div class="ubbcode-body">Differences at the subframe mountings could create this too.
</div></div>
But then the wheelbase would be 1 inch shorter.
CRG info on engine mounts:
http://www.camaros.org/engine.shtml#EngineMounting
Jan Suhr
Stockholm, Sweden
1969 Camaro Z/28 ProTouring
My Car My Book My Photos
Old 01-10-2014, 05:17 PM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: jannes_z-28</div><div class="ubbcode-body"><div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: PeteLeathersac</div><div class="ubbcode-body">Differences at the subframe mountings could create this too.
</div></div>
http://www.camaros.org/engine.shtml#EngineMounting </div></div>
Yep and worth checking too!
Old 01-10-2014, 11:21 PM
plumL78 plumL78 is offline
a stock 67 BB drive shaft is 50 1/4 50 3/8
Old 01-11-2014, 06:32 PM
Ok just measured and the driveshaft is 51&quot;. I measured from end of loop
to end of loop. So center hole to center hole about 50&quot; Then I measured
the other car the same way and it measured 52&quot;
I have a 67 camaro subframe in storage I will get out and do some measuring
and check it against this car.
67 RS/SS L78 0-0
Old 01-11-2014, 09:25 PM
al8apex al8apex is offline
I remember speaking with Al Maynard in the 70's and he moved the engine back on his &quot;stock&quot; drag Camaro (I think it was a 67). Apparently it was &quot;allowed&quot; in the &quot;stock&quot; class or he was cheating and didn't get caught ... he mentioned slotting the engine/transmission mounts to move it back
He also said the entire front end was acid dipped, sub frame, suspension and all ... all the weight he lost he put in the rockers right in front of the rear wheels in lead ...
Jim R
Scottsdale, AZ
Old 01-27-2014, 11:43 PM
----That would be Al, alright! I miss him dearly......Bill S
Old 02-02-2014, 03:44 PM
RichSchmidt RichSchmidt is offline
If you swap the frame stands from side to side it sets the engine back 1&quot;. So know you know.
