Old 02-25-2014, 08:00 PM
Default Re: Next Years Power Tour Car Part 2
Told ya...."Lesson learned guy"!
Old 03-01-2014, 01:08 PM
kwhizz kwhizz is offline
More Lessons learned............Do "NOT" use rubber fuel line for transmission cooler line......Ask me how I "NOW" know that!!!!.........LOL.........
Old 03-02-2014, 02:56 AM
bulletpruf bulletpruf is offline
Just finished going through the entire thread. Am in awe of your progress and fab skills. Gorgeous car, great build.
Scott
Please check out my YouTube channel for vintage car and truck rescues and rebuilds! https://www.youtube.com/c/THEBULLETPROOFGARAGE/videos
Old 03-06-2014, 09:13 PM
A simple issue to pass along for others to not make the same mistake as I did.......I used Fuel line for the transmission cooling lines to the radiator.......after blowing holes in the lines (3 times) and after the last time the car had to be brought home on a Flatbed.....I didn't know really what the Heck was going on.......I called RPM transmissions and after explaining what was going on......he explained that you can't use fuel line for this purpose......It seems the trans fluid attacks and weakens the Rubber used for fuel lines......the trans he built for me has about 300 PSI line pressure when put in reverse and that's why I was having these problems.......It was blowing thru the hose at it weakest point.........So....I already replaced the front section of lines (from the starter forward) with hard lines........and I was going to finish the rest but it seems me and tube benders don't get along.......so after going thru a bunch of hard lines I went and bought some correct trans rubber hose and installed them and everything is now fine........Now maybe I can make it to the alignment shop without the trans line blowing out......LOL.......
On to the last Issue that I had to deal with was setting the pinion angle.....The Ridetech set-up is great .....But.....because of the little extra angle of my engine trans combo when I tried to adjust it using the upper adjustable arms........It just rolled the rear end back into the Coil Overs..........So.....as the lower arms are fixed length and non adjustable.......I talked to the Tech guys at Ridetech (Great Guy's) and what I did was bought threaded Bungs and Rod Ends........So.....we cut off the ends of the lower arms and welded in the new bungs with the adjustable Rod Ends........So.....I figured out the angles and how much shorter the lower arm needed to be and adjusted them and put everything back together.......Bingo........hit it the first time......and when I ordered those parts I also ordered the rear sway bar assy.......so I got everything installed and finished.......Now we just need some dry Salt free roads to get the alignment completed......Get the exhaust system installed.........Get the car to Donnie at Frame-up.......Then off to Stefano at Nickey for the Tune.........
Ken
Old 03-06-2014, 10:05 PM
IM RARE IM RARE is offline
WOW that black paint is really shining... good Job Hose guy
Old 03-06-2014, 10:43 PM
WILMASBOYL78's Avatar
There's a little drip of grease on that one fitting...please have it cleaned [img]<<GRAEMLIN_URL>>/beers.gif[/img]
02 Berger 380hp #95
Lots of L78 Novas
Join National Nostalgic Nova!
70 Orange Cooler
69 Camaro
Old 03-06-2014, 11:16 PM
Looking great!!
Old 03-07-2014, 04:01 AM
CC Rider's Avatar
CC Rider CC Rider is offline
Grease Guy!
Rick
1966 Chevy Caprice 427-390
Old 03-11-2014, 11:52 AM
A couple of things........I made it to the alignment shop today.....LOL.....I actually didn't blow up any transmission lines.......I guess when you use the right product for the application .......It works......LOL.....anyhow....The front end is now aligned and set up........I also sent out my stock am radio and had it converted to am/fm stereo /satellite Sirius ready.......got everything in and hooked up with Radio Margaritaville ..............great cruising station...........I also ordered an exhaust kit with all mandrel bends and Dynomax #17749 mufflers.....2 1/2&quot; system.........should be here in a couple of days......Good weekend project......The other thing I'm not too crazy about is the brake system.........It was recommended to go with a 7/8&quot; bore master non power system..........well......I'm not very impressed with the stopping power and may be switching to a Power system in the near future.........anyhow......here are some pic's....Time to call Stefano at Nickey and get the old Beater over there and wake it up......LOL
Old 03-11-2014, 12:50 PM
Plowman's Avatar
Plowman Plowman is offline
What are the final after alignment measurements,if you have them.
