#591
Ken told me he was getting 21 mpg at 85 mph on the Power Tour and that Charley was having a hard time keeping up...... [img]<<GRAEMLIN_URL>>/wink.gif[/img]
Rick Nelson Musclecar Restoration and Design, Inc (retired) www.musclecarrestorationanddesign.com https://www.youtube.com/watch?v=62r-6vgk2_8 specialized in (only real) LS6 Chevelle restorations |
#592
Yep.........Charley has driv'in his Beater Camaro on a couple of Power Tours now........Time for a new one......
![]() The Best things in life......Aren't Things |
#593
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: kwhizz</div><div class="ubbcode-body">Yep.........Charley has driv'in his Beater Camaro on a couple of Power Tours now........Time for a new one...... </div></div>
Charley goes through Camaro`s faster than he does shoes, as in sneakers [img]<<GRAEMLIN_URL>>/naughty.gif[/img] Dan
69 300 Deluxe Post Sedan Frost Green 69 SS396 300 Deluxe Post Sedan Lemans Blue SOLD 70 Buick Skylark Post Sedan Gulfstream Blue 70 Buick Skylark Post Sedan Burnished Saddle http://m.youtube.com/watch?v=PM3DE8qI2NY https://m.youtube.com/watch?v=Yn4xEmGypUw |
#594
In 60 pages, I'm sure someone beat me to it, but...CAN I HAVE IT?
69 camaro Z-28 burnished brown X-77 bought 1978 70 camaro Z28 forest green M40 black vinyl roof PROJECT 99 camaro SS Hugger Orange 6speed no t-tops 1 of 54 11 cts-v black diamond edition wagon 556hp GONE 15 camaro Z/28 white AC brand new |
#595
The Season is just about over here in Wisconsin........Overview of the year since the completion in May......7276 miles of trouble free driving this year......There is still a few "Tweaks" needed to make the car up to the standards ..........The first issue I will be dealing with is the Oil pan / Drivetrain angle issues.........again......on the initial install the Holley 302-2 pan was not available so I used the -1 pan........I had to raise the front of the engine to clear the tie rod ends, which gave me a little more angle than I wanted.......to get the angle more in line I have the rear of the trans shimmed up as high as it would go to help out with the angle issue......In doing this the trans is hitting inside the trans tunnel and giving a slight vibration ........So....even though mechanically the angle is now dialed in.....I am going to change the -1 pan out for the -2 pan so I can lower the engine slightly to alleviate that issue.......
The second issue is the reproduction dash Pad in the car........Repro Dash pads are Junk in my opinion and don't fit worth a crap......I've been looking for a OEM one for months to send to Just Dashes for restoring........I finally found one and sent it off to them for restoring.......they have a twelve week lead time so that makes the timing about perfect.......I also bought a DSE wiper motor assy so when I take the dash out for the pad install I can change around the wiper switch and wiring......... All in all it's been a real treat to drive this car around the Country this season......The Torque and Power these engines make is just Crazy...........along with the average for the season of 20 MPG are just outstanding ............. ![]() ![]() ![]() Stay tuned........
#596
Nice!
Bruce Choose Life-Donate! |
#597
Tweaks are fun. [img]<<GRAEMLIN_URL>>/biggthumpup.gif[/img]
Rick 1966 Chevy Caprice 427-390 2012 Chevy Camaro RS Convertible ![]() |
#598
So........Winter is here and it's time for the "Tweaking"..........The OEM Dash Pad should be coming back from Just Dashes in a couple of weeks........so after installing it I won't be tortured next year looking at that piece of crap reproduction Pad with the ends flipped up because it's too narrow to fit.......sheesh.....you would think by now the aftermarket guy's would have figured Mold Shrinkage into the picture......Just Say'in......Now to deal with the Driveline angles....... After loading the Tremec driveline app on my phone (you use your smartphone as a level and hit the Engine.....Driveshaft....and rear end housing ....and it compares the results and let's you know if everything is good...or Bad) and seeing Red... I decided to get around to starting the process of changing to the -2 pan.....so....After double checking everything....... it ended up with the Drivetrain Angle at 5 Deg down ....... Driveshaft 2 Deg up....... Pinion -1......The car rode well without any Vibration.....But.....at 70 MPH when I let off the gas I could feel where the universals were fighting themselves.........after calculating how much I would have to drop the front of the engine to get to 3 Deg ......It ended up that I would have needed to drop the engine mounts down 1 5/16.......Even with the -2 pan it would be problematic..........so.......After seeing another persons purchase to deal with this issue with parts available from the Driveshaft Shop .......... I called Frank there and we discussed my concerns.....Gave him all the info and he is building me a 3 1/2" Aluminum driveshaft with the trans end having a CV joint and a conventional universal at the rear end........Should be here in a couple of weeks.........Again.....The car drove perfect, but.....I just knew the I didn't hit the "Sweet Spot" with the angles.........This should be the final fix that will let me feel 100% about the Chevelle..................After thinking about it a little more..........everything was built around the engine sitting where it is and lowering it much would have really opened up a can of worms.....This seems to be the simplest and best way to solve that one little issue that was O.K.......But not up to standards........So.....That also means if anyone is going to do a LS swap and will be needing a Holley 302-2 Pan....Baffle system and Oil Pan Gasket.....I just happen to know where there's an extra one for Sale......LOL
#599
Very cool...you'll have it done in no time! Well....after some time in the sun! [img]<<GRAEMLIN_URL>>/naughty.gif[/img] [img]<<GRAEMLIN_URL>>/headbang.gif[/img]
#600
Ken;
Would you have been able to bring the angles in line with a pair of adjustable upper control arms for the rear end? |
