Old 10-17-2014, 11:46 AM
69L78's Avatar
69L78 69L78 is offline
Default Reverse lock out rod 5793 for 69-72 Nova
Is the 5793 lower reverse lockout rod the same for BB or SB?
Old 10-18-2014, 04:25 PM
69L78's Avatar
Default Re: Reverse lock out rod 5793 for 69-72 Nova
all the Nova guys on here and no one knows if the reverse lockout rod is the same for BB or SB.
Old 10-18-2014, 05:47 PM
John Brown's Avatar
Must not be.
Looked in my Nova AIM and it shows ~
part 6
3955793 ROD
3955795 396 ENG.
John Brown
Old 10-18-2014, 05:50 PM
Wilma would know!
Old 10-18-2014, 05:56 PM
1969L78Nova 1969L78Nova is offline
Yenko Paid Member
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: John Brown</div><div class="ubbcode-body">Must not be.
part 6
3955793 ROD
3955795 396 ENG.
X 2</div></div>
Old 10-18-2014, 06:28 PM
WILMASBOYL78's Avatar
WILMASBOYL78 WILMASBOYL78 is online now
Difference is most likely do to the driveline offset on the BB cars...I've never seen both parts side by side...but, you could probably make the SB part work in a pinch. Steering column to frame should be the same...bracket too...then the angle changes slightly.
Wilma
**Sammy...how you doing son?
02 Berger 380hp #95
Lots of L78 Novas
Join National Nostalgic Nova!
70 Orange Cooler
69 Camaro
Old 11-15-2016, 08:52 AM
69novamanrick 69novamanrick is offline
These posts are older, but yes the 3955795 is for the BB only. I agree with Wilma that in a pinch you can make the SB rod work but the 3955795 is correct for BB due to length and offset. The BB Nova rod is also not correct for the BB Camaro either, as some may think, due to the reverse lever on the tranny being different on a Camaro. I believe here again you can make the SB or BB rods interchange from Nova to Camaro and visa versa, but technically the two are different due to the shift lever on the tranny.
Old 11-15-2016, 02:00 PM
YENKO DEUCE REGISTRY's Avatar
The trans reverse lever is diff betw/ the Nova and Camaro??
Marlin
67 RS Camaro-327/250hp, 2speed Glide, &amp; 3.08 Open (Danny's Ride)
Old 11-16-2016, 10:31 AM
Yes, the reverse lever on a 69 Camaro is flat, where the 69-70 Nova has about a 1/4&quot; offset to it. Now this info is good for the 69-70 BB Nova and 69 Camaro. I believe some of the Novas like a Yenko Deuce used the
same shifter, linkage, and levers as a Camaro. I've got photos to show of BB Nova levers verses 69 Camaro, but haven't figured out how to post them on here.
Old 11-16-2016, 01:33 PM
Learn sumthin every day... [img]<<GRAEMLIN_URL>>/biggthumpup.gif[/img]
Marlin
