Old 10-18-2014, 06:28 PM
WILMASBOYL78's Avatar
Default Re: Reverse lock out rod 5793 for 69-72 Nova
Difference is most likely do to the driveline offset on the BB cars...I've never seen both parts side by side...but, you could probably make the SB part work in a pinch. Steering column to frame should be the same...bracket too...then the angle changes slightly.
Wilma
**Sammy...how you doing son?
02 Berger 380hp #95
Lots of L78 Novas
Join National Nostalgic Nova!
70 Orange Cooler
69 Camaro
