Old 12-18-2014, 08:22 PM
x77-69z28's Avatar
Default Re: Supercar Photographs
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: markinnaples</div><div class="ubbcode-body"><div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: markinnaples</div><div class="ubbcode-body">All of these dark green cars just look so much better than they did back in the 70's and 80's when they were just dated old cars. Everyone wanted to change the green ones to any color but green, but now I'd love to own a dark green one. </div></div>
Thanks guys, and I should edit my post to include Frost Green in addition to Fathom Green; and for the record, I've always had a soft spot for Burnished Brown. [img]<<GRAEMLIN_URL>>/smile.gif[/img] </div></div>me too!!!
Old 12-18-2014, 10:52 PM
mrays mrays is offline
#104. This COPO Camaro was sold new at Central Chevrolet - Oldsmobile in London Ontario. It is VIN #N648156 and order #NOR297484. It has a TH400 with the shift lever on the column. It was advertised as a numbers matching car.
Old 12-19-2014, 02:33 PM
Day2_69Z Day2_69Z is offline
OOPS....ANOTHER UPSIDE DOWN HOOD SEAL....SMEXPERTS, ..DUH..
Im gonna keep making it aware until I see 3 in a row the right way. ritflmao
and , Yes, dynamite car ! [img]<<GRAEMLIN_URL>>/Can-I-Have-It.gif[/img]
Day Two Specialties /High Quality Muscle Car Parts.
Old 12-19-2014, 02:47 PM
The last two shown are not upside down hood seals. They just don't lay out like normal. When you see the upside down ones they are really obvious.
Old 12-19-2014, 02:53 PM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Day2_69Z</div><div class="ubbcode-body">OOPS....ANOTHER UPSIDE DOWN HOOD SEAL....SMEXPERTS, ..DUH..
Im gonna keep making it aware until I see 3 in a row the right way. ritflmao </div></div>
They have to be turned inside out,before they can be installed upside down too,like on the fathom green car.
I call them inside/upsides.
Old 12-19-2014, 03:02 PM
Here is a example of upside down inside out with the lip
Old 12-19-2014, 07:57 PM
[img]<<GRAEMLIN_URL>>/youguysrock.gif[/img]
FUNNY ,,,, ..................... [img]<<GRAEMLIN_URL>>/stupid.gif[/img]
Old 12-19-2014, 08:06 PM
njsteve njsteve is offline
If I recall correctly GM was selling an NOS version that the original vendor had assembled wrong - the ends were glued together backwards so that the inner lip was actually on the outside and vice versa. I had one of them on my Z11 years ago and could not get it to install properly in the right-side-up position. I tried cutting it at the glue seam and reglueing it the other way but it was all kinked up due to the age of the rubber. I ended up using the original seal.
Old 12-20-2014, 11:45 AM
KevinW KevinW is offline
The seals pictured need to be spayed outward (blue tape work well to hold it) until the seal holds the shape properly, but they are not upside down (Charley's pics are upside down). The upside down seals really bug me, enough that I wrote instructions how to fix them 5 years ago [img]<<GRAEMLIN_URL>>/smile.gif[/img] I have even help people fix them at car shows [img]<<GRAEMLIN_URL>>/laugh.gif[/img]
www.camaros.net/forums/showthread.php?t=150415
69 327 convertible (driver)
Old 12-20-2014, 12:24 PM
thanks for chiming in Kevin.
Taping the seal is a good idea as I have done it with good results on NOS &amp; reproduction seals.
The sharp wrinkles then can be further removed by placing it in the sun all day or two till they reform to a full circle.
Some of the above cars (reviewing the many pages) do have the seals inside out ,upside down and most just upside down as noted by Kevin in the Team Camaro thread, with unopened lips.....as recently, I reinstalled 2 seals on friends cars the same way,by opening the lip from the seal.
Still...... need to see -3- in a row correct ones to cheer on. before &quot;I go away&quot;. lol
