Old 01-21-2015, 08:14 PM
Fast67VelleN2O's Avatar
Default Re: COPO BE rear on craigslist
Day 2 is Life.
Old 01-21-2015, 08:36 PM
Day2_69Z Day2_69Z is offline
Wow, that is a bad disquise, hammer dents and stamp.....lotta red flags.
I wonder whats under the cover ?
There is definately a curved letter under the E...a U or C or ?
The font looks right on , but the position of the E is terrible.....
jmo...I'd pass, if I needed a real one I'd contact Enio...or Chuck
Day Two Specialties /High Quality Muscle Car Parts.
Old 01-21-2015, 09:05 PM
luzl78 luzl78 is offline
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: L78steve</div><div class="ubbcode-body">Looks like a BS stamp to me. </div></div>i take it back. It's a former S as steve says, not an F.
Old 01-21-2015, 09:18 PM
x77-69z28's Avatar
Or BL
Old 01-21-2015, 09:21 PM
the427king's Avatar
Ive had a BV rear with 519 date before. The V almost looks still visible under the E now that I look at it again.
Ebay Auctions http://www.ebay.com/sch/427-king/m.h...=16&amp;_rdc=1
No Fisher priced toys here
Old 01-21-2015, 09:44 PM
m22mike's Avatar
m22mike m22mike is offline
The other fishy thing is the placement of the eaton posi single &quot;E&quot; under the main stamp, I have never seen one that far from apporximate center
Mike
Old 01-21-2015, 11:19 PM
mbxlesney mbxlesney is offline
Doesnt the BE rearend have straight axle tubes from the carrier to the axle flange whereas the BV and other lesser 12 bolts have a taper in the last 1/2 inch or so at the rear side of the flange where the backing plate bolts are. I always thought BE 12 bolts had the larger Full Sized (Impala) etc outboard axle bearings and larger carrier bearings also? I know there was no pic of this area but can someone tell a BE by external appearances besides the stamping. Ive read the gears are heat treated also. Can anyone shed any light on this? Just curious Thanks
Kim
1970 Nova Fathom Blue L78 M21 3:55
1970 Nova Classic White 454HO THM400 4:10
Old 01-22-2015, 01:59 AM
Steve Shauger's Avatar
Administrator
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: m22mike</div><div class="ubbcode-body">The other fishy thing is the placement of the eaton posi single &quot;E&quot; under the main stamp, I have never seen one that far from apporximate center
Mike </div></div>
Mike I agree with you. I'm betting it started life as a BL 307 non posi and the E (Eaton ) was added as well.
www.yenko.net
www.vintagecertification.com
Old 01-22-2015, 02:25 AM
Stefano Stefano is offline
Same 12 bolt housing.
Click to visit the Nickey Performance Facebook--&gt;
Old 01-22-2015, 02:51 AM
The tapered tubes or not mbx' is thinking of is actually a JL8 thing.
I forget which is what but believe tapered or not indicates factory installed JL8 units compared to over the counter service parts.
Back to the bogus BE, is the 'stamping' not done w/ acid...a Timothy Leary follower perhaps?
Note the craters you can see when looking closely, again similar work to some altered pads and stampings we've looked at here before.
