Doesnt the BE rearend have straight axle tubes from the carrier to the axle flange whereas the BV and other lesser 12 bolts have a taper in the last 1/2 inch or so at the rear side of the flange where the backing plate bolts are. I always thought BE 12 bolts had the larger Full Sized (Impala) etc outboard axle bearings and larger carrier bearings also? I know there was no pic of this area but can someone tell a BE by external appearances besides the stamping. Ive read the gears are heat treated also. Can anyone shed any light on this? Just curious Thanks
Kim 1970 Nova Fathom Blue L78 M21 3:55 1970 Nova Classic White 454HO THM400 4:10 |
Same 12 bolt housing.
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Stefano</div><div class="ubbcode-body">Same 12 bolt housing. </div></div>
Thanks Stefano and Peter for the replies. One could never stop learning about these cars...especially COPOs. Pete I did remember a article on a 12 bolt with tapered axle tubes and maybe it was about the JL8 [img]<<GRAEMLIN_URL>>/beers.gif[/img]
The hammer marks would suggest to me that it was mistamped when manufactured originally . Assembly line guy hit it with the wrong stamp flipped his hammer over, peened it back smooth or reasonably close and restamped it with the E.You guys seem to forget that these were all done by hand and mistakes were made.Someone needs to snap it up for their next COPO restoration project.
I have been corrected. It appears that if a part was mistamped at the factory, a special stamp was stamped over the mistake and then the correct stamp placed elsewhere. Learn something every day.
