Old 03-11-2015, 12:40 AM
Default Re: Ryan Weaver's 1969 Olds Cutlass S W31 Club Coupe
Yep, Lucas Rocks [img]<<GRAEMLIN_URL>>/biggthumpup.gif[/img]
Old 03-11-2015, 01:01 AM
Ryan1969Chevelle's Avatar
Thx
Ryan
Old 03-11-2015, 02:30 AM
83hurstguy 83hurstguy is offline
Awesome car, looking forward to seeing it at MCACN!
I would advise against silicone brake fluid unless you are just looking for a show queen. The water not absorbing into the brake fluid isn't necessarily a good thing, as the water will then be capable of &quot;flashing&quot; to vapor if the fluid goes over the water's boiling point, which leads to soft pedal. The hygroscopic action of the brake fluid is there to be able to absorb some moisture without affecting braking performance until it becomes oversaturated (and you bleed). On the plus side, silicone brake fluid doesn't eat paint. But that's about the end of the plus sides...
Luke
'68 H/O W45
'70 Cuda
Old 03-11-2015, 07:06 AM
Good to know!
Definitely not going to be a show car, so I will stay away from si.
Ryan
Old 03-11-2015, 12:48 PM
DW31S's Avatar
DW31S DW31S is offline
Ryan can you please measure wheels and post oh a doing so. I've seen '69 W-31 cars that were &quot;supposedly&quot; original with different width rims. I don't know if the Canadian destination could be a factor. Soliciting opinions or comments on this. Please take a picture with ruler or tape measure showing the overall width. Thanks in advance.
On another note, my 4-speed guy says not to use synthetic gear lube in Muncies. Seems the oil is too slippery and won't cling to the rotating parts.
Old 03-11-2015, 01:23 PM
69 Post Sedan's Avatar
Ryan.....I HIGHLY recommend Sta-Lube for your Muncie.
Sta-lube
Kurt
1968 Schwinn Orange Krate
1969 Schwinn Pea Picker
1968 Schwinn 5-Speed
1970 Schwinn 3-Speed Deluxe
1973 Schwinn 5-Speed Suburban
All Original Paint Bikes
Old 03-12-2015, 12:46 AM
Hi Dave, I will measure the rims but all have tires on so need to reach around them to get a width.
Hi Kurt, your vote is dually noted:-) you really beat on you M23:-)
Ryan
Old 03-12-2015, 12:58 AM
Did some more digging tonight!
Found the casting numbers on the rear end, 402227. CFD ?
Ryan
Old 03-12-2015, 01:01 AM
I also found the stamp TM just as I suspected! Same as the black/topaz twin to my car:-)
Old 03-12-2015, 01:13 AM
Cleaned up and found stamps on the transmission as well
Haven't tried to decode them yet
Ryan
