Old 04-16-2015, 04:41 PM
Zman1969 Zman1969 is offline
Default Re: Webster's 67 Bel Air Conversion
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Charley Lillard</div><div class="ubbcode-body">I'm 62 and also have had more BBC than I can count. Currently in my barn is a 509&quot;, 494&quot;, 427&quot; 427&quot; and 427&quot;. They are all cool engines but nothing compared to my LS. Sorry if the thought of a computerized engine bugs you that much. Seems more like you don't want to learn any new tricks.
</div></div>
Time to Poke Charlie
wait for it....
can I have it?
Great Build as usual Kwhizz!
69 RS/Z 302 VE3 Daytona
69 Chevelle SS 396 375
69 T/A clone LS6/6 speed
90 Formula 350
Old 04-16-2015, 06:40 PM
I'll sell it to you. [img]<<GRAEMLIN_URL>>/burnout.gif[/img]
Old 04-20-2015, 11:34 PM
kwhizz kwhizz is offline
1.Moving along........Got the Power Steering reservoir mounted ......Mark brought over the correct A/C compressor.....got that installed using Kwik Performance brackets.......(Great Stuff).....got the column shift linkage installed ...... Torque converter bolted up.......I started getting the fuel system installed........Mark modified the stock tank for the LS application........I got the Filter/ Bypass installed and started on the fuel lines......LOL........The lines that Mark supplied are different than the ones I was used to using and after trying for 45 minutes to get one fitting installed.........I threw in the towel.......So.....The car is going back to Mark with just a bunch of Mickey Mouse things left to do........In the pic with the A/C compressor installed, I had a spare 99.5&quot; belt laying around but the directions call for a 101&quot; belt.....the one I had was too short as you can see so Mark will be getting the proper sized one.......New Driveshaft is also installed.....
Old 04-21-2015, 12:46 AM
Looking Great.....See you both at Mundelein.....at our usually watering hole :-)
Old 04-21-2015, 01:19 AM
Very cool!
Old 04-26-2015, 08:03 AM
slammed1 slammed1 is offline
Great build once again Ken!!You always find the most clean solid cars around as project builds. The 67 looks great in white with the steelies and dog dish.
just a gearhead
1966 Belair sleeper
Old 05-02-2015, 10:29 PM
L78biscayne's Avatar
L78biscayne L78biscayne is offline
not quite as dramatic as kens days just finished up a lot of wires
1967 bel air 5.3 4l60e
Old 05-02-2015, 10:31 PM
Dakota digital vhx dash
Old 05-02-2015, 11:52 PM
Kool................Getting closer......
Old 05-04-2015, 02:22 AM
No hurry. You have 4 weeks.
