Old 08-30-2015, 02:00 AM
70LS6454 70LS6454 is offline
Default Re: 1970 Canadian Built Chevelle Extremely Documented
Looking really good Luis!!
Old 08-30-2015, 02:20 AM
Good Job sir!!
Mike
Old 08-30-2015, 03:05 AM
SS427's Avatar
SS427 SS427 is offline
All your hard work is paying off quite nicely Luis.
Rick Nelson
Old 08-30-2015, 02:16 PM
Great job Luis !
Old 08-30-2015, 08:43 PM
WILMASBOYL78's Avatar
Amazing attention to detail...very nice [img]<<GRAEMLIN_URL>>/biggthumpup.gif[/img]
I have a question...did BB Chevelles come with that 4 blade fan ?? I always thought they had a clutch fan...just curious.
wilma
02 Berger 380hp #95
Lots of L78 Novas
Join National Nostalgic Nova!
70 Orange Cooler
69 Camaro
Old 08-30-2015, 08:46 PM
Yes,hydraulic liftered engines got the 4 blade as std.Unless ordered with A/C,then they received the 7 blade w/clutch.
L-78 &amp; LS-6 came std. with 7 blade w/clutch.
Old 08-31-2015, 12:10 AM
Luis Luis is offline
Thank you for the kind comments, guys.
I've being collecting parts since 1997 when I bought it. Carb, alternator, distributor, p/S pump, fuel pump, thermostat housing, starter, water pump, 4 blade fan, manifolds, all pulleys and brackets are 100% date coded. These parts have not been cheap by any means.
Most difficult to find were the shock$$$$, they are currently being restored by Dan. Should be done by next week. Lots and lots of other correct date coded parts throughout the chassis. Amazing you can find part numbers or stamping on the smallest parts.
Did you guys noticed the rear upper control arms...they have two holes each. Seems to be a Canadian difference from those built in the US.
Next in line buy tires and mount them on a set of October 69 AO wheels. Unfortunately Uniroyal Tiger Paws are not reproduced, so it will either be Goodyear or Firestones. Then re-chrome 1/4 inch deep center caps to go along with a set of NOS trim rings. Last add all decals. Hope to have it ready for next year Maryland Chevelle Club show.
I love the Gardner exhaust, did you notice the no part# exhaust tips. System fits perfectly on the chassis. I got the ones with the turbo mufflers. Kudos to Eric and his Gardner Exhaust Team.
Have to thank Billy's Hot Rod and Performance for his work on the chassis from disassembling, sanding, painting, and assembling. Rick, did the front end. Have to love the markings. Doug Yoder for his assistance with paints and supplies. Chris W. with parts and part #s.
Old 08-31-2015, 01:09 PM
----You are doing great!!! I would recommend the Goodyears as they are at least closer to the original style then the Firestones......Bill S
Old 09-27-2015, 12:26 PM
So body back on the chassis for test fitting doors, hood, fenders, etc. Once fitting has been completed back off the chassis. The reason for the door hinges pic is there have been occasions when points have been deducted when cars have been judged. Judge claims not painted...owner yes they were painted. Clearly these have the original paint. Having a friend restore then.
Funny feeling...it actually looks like a car.
Old 09-27-2015, 01:11 PM
Here are pics of the restored shocks.
