  #11
Old 02-17-2016, 12:57 AM
kwhizz kwhizz is offline
Default Re: 57 Nomad Project.........
O.K.........Back at it..........Made a simple mounting plate for the control modules out of 1/4" plastic........Then I got it mounted in the fender well area so it is basically out of the way......Gonna make a mounting bracket for the GM supplied engine compartment fuse box.......I also got the trans cross member bolted in and got the engine drivetrain angle set......Need to make a couple 2 degree angle blocks to change the pinion angle to match the engine.......I also spun the engine over today to get some oil pressure......after getting all the wiring finished up next week I still need to deal with the fuel system......among other things....but...we are getting closer
