Old 03-23-2016, 11:09 PM
427TJ's Avatar
427TJ 427TJ is offline
Default Re: Here's my beater
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: 300deluxe</div><div class="ubbcode-body"><div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: 427TJ</div><div class="ubbcode-body">I'd add only a set of Coker F70 pinstripe whitewalls with those stock wheelcovers. You don't see that every day. Would definitely turn heads. </div></div>
I was thinking about some F70-14 redlines, they might look good also...but the white pinstripe tires might look even better </div></div>
Nah, go with the white pinstripe look. Redlines would look wrong. Maybe a size bigger than stock. F70 should work.
