Old 03-23-2016, 08:40 PM
Ryan1969Chevelle's Avatar
Default Re: Ryan Weaver's 1969 Olds Cutlass S W31 Club Coupe
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Woj</div><div class="ubbcode-body">Looking good Ryan. That frame cleaned up pretty well.
Keep up the good work.
Phil Woj. </div></div>
Thanks Phil:-)
I get a little surprised what I don't know......... I don't even know what I don't know:-) Dangerous:-)
I am super excited about the condition of the frame and suspension pieces:-)
Ryan
PS: Engine builder visits are on hold for two weeks, I am not pushed for time and one builder is away for two weeks so I will resume when he returns.
Old 03-23-2016, 08:42 PM
[img]<<GRAEMLIN_URL>>/biggthumpup.gif[/img]
Old 03-24-2016, 12:49 AM
So I added a little fun to the build:-)
Tracker1 has the perfect addition to my W-31 a Hurst Ram Rod Shifter to go behind my Ram Rod 350:-)
This will be perfect on my M22!!
Ryan
https://www.yenko.net/ubbthreads/ubbt...ter#Post651641
Old 03-24-2016, 02:23 AM
Leave that cut up floor hump alone.....until you have this ready to install [img]<<GRAEMLIN_URL>>/biggthumpup.gif[/img]
Old 03-24-2016, 02:32 AM
That's the new plan:-)
I have a new 4 speed hump section lined up and it will sit aside for a little while:-)
Ryan
Old 03-24-2016, 02:44 AM
Did you ask Tracker1 if the Ram Rod comes with bushing shims? You will have to do research.....if they are needed for your application on an Olds? I believe they are needed.
I will email you a picture of the bushing.
Old 03-24-2016, 02:45 AM
69 Post Sedan's Avatar
Ryan.......here's my two cents. If you don't mind modifying your tunnel......do it now cause you'll regret not doing it later and eventually, you WILL put the Ram Rod in. Ask me how I know. [img]<<GRAEMLIN_URL>>/scholar.gif[/img]
Kurt. [img]<<GRAEMLIN_URL>>/[/img]
1968 Schwinn Orange Krate
1969 Schwinn Pea Picker
1968 Schwinn 5-Speed
1970 Schwinn 3-Speed Deluxe
1973 Schwinn 5-Speed Suburban
All Original Paint Bikes
Old 03-24-2016, 03:06 AM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: 69 Post Sedan</div><div class="ubbcode-body">Ryan.......here's my two cents. If you don't mind modifying your tunnel......do it now cause you'll regret not doing it later and eventually, you WILL put the Ram Rod in. Ask me how I know. [img]<<GRAEMLIN_URL>>/scholar.gif[/img]
Kurt. [img]<<GRAEMLIN_URL>>/[/img] </div></div>
I am on board:-)
This has been sitting in the back of my mind for a while, and I agree to restore/repair the hump would mean never cutting it up again, so fun now Concours later:-)
I will have the piece of floor on the shelf ready to go.
Ryan
Old 03-24-2016, 03:08 AM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Postsedan</div><div class="ubbcode-body">Did you ask Tracker1 if the Ram Rod comes with bushing shims? You will have to do research.....if they are needed for your application on an Olds? I believe they are needed.
Dan </div></div>
I will find out. I think I remember the part from Ricks RR:-)
Ryan
Old 03-24-2016, 03:49 AM
Things are looking great Ryan. You will be stoked with the Ram Rod.
Jason
