Old 03-24-2016, 11:27 AM
69 Post Sedan's Avatar
Default Re: Ryan Weaver's 1969 Olds Cutlass S W31 Club Coupe
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Postsedan</div><div class="ubbcode-body">Did you ask Tracker1 if the Ram Rod comes with bushing shims? You will have to do research.....if they are needed for your application on an Olds? I believe they are needed.
I will email you a picture of the bushing.
Dan </div></div>
Dan, that shifter and mount are the second design, same as mine, so it shouldn't need the bushings/spacers. [img]<<GRAEMLIN_URL>>/biggthumpup.gif[/img]
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: SuperNovaSS</div><div class="ubbcode-body">Things are looking great Ryan. You will be stoked with the Ram Rod.
Jason </div></div>
^^^^X1000^^^^
1968 Schwinn Orange Krate
1969 Schwinn Pea Picker
1968 Schwinn 5-Speed
1970 Schwinn 3-Speed Deluxe
1973 Schwinn 5-Speed Suburban
All Original Paint Bikes
Old 03-24-2016, 11:56 AM
10-4 [img]<<GRAEMLIN_URL>>/headbang.gif[/img]
Ryan - you are good to go [img]<<GRAEMLIN_URL>>/[/img]
Old 03-24-2016, 12:39 PM
Ryan1969Chevelle's Avatar
Thanks guys!!!
Ryan
Old 03-24-2016, 11:16 PM
Rushed around like a fool after work today:-)
Went to Terry's and borrowed his welder, raced back home in an ice storm to meet my friend the welder. We measured using the original frame drawing and what I had laid out was bang on using diagonal, side to side and front to back measurements:-) I wanted a second guy to go over them with me before opening up the holes for the replacement metal rings, as it is hard to get accurate measurements solo.
We ground out the bad material (about 1/4 inch around two body mount holes) and welded in two more rings, then ground with a flapper wheel and used the die grinder underneath to dress it up, looks like a million bucks:-)
I felt like a dink, I had to steal the power from the stove for the welder as the family was cooking chili for dinner:-( I guess I have heard of worse things:-)
Frame is now ready to go back form blasting:-) Monday/Tuesday.
Ryan
Old 03-24-2016, 11:41 PM
Unless your shipping the frame in an enclosed tralier.....you now better wait for all the snow to melt :-(
I hate snow [img]<<GRAEMLIN_URL>>/thumbsdown.gif[/img] Well done.
Old 03-25-2016, 12:40 AM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Postsedan</div><div class="ubbcode-body">Unless your shipping the frame in an enclosed tralier.....you now better wait for all the snow to melt :-(
Dan </div></div>
I will make sure she gets to and from safe and sound and dry!!!!
Ryan
Old 03-25-2016, 12:48 AM
RamblerDealer RamblerDealer is offline
I think it may all melt Saturday and Sunday, so here is hoping Monday is clean sailing back to the blaster.
Old 03-25-2016, 09:22 AM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: RamblerDealer</div><div class="ubbcode-body">I think it may all melt Saturday and Sunday, so here is hoping Monday is clean sailing back to the blaster. </div></div>
I second that!
Our Power has been out for 8 hours so far......... Hope the melting starts soon!!
Ryan
Old 03-25-2016, 10:11 AM
DW31S's Avatar
DW31S DW31S is offline
With that power outage, are we to suspect another little Weaver in 9 months??? Just jabbin' atcha Ryan!!! Keep up the good work, Bro.! And by the way, good deal on that shifter!
Old 03-25-2016, 12:16 PM
__________________________________________________ ____________________________
Ha, Then the Olds would never get done [img]<<GRAEMLIN_URL>>/no.gif[/img]
