Old 06-23-2016, 12:08 PM
cook_dw's Avatar
cook_dw cook_dw is offline
Default Re: Well that was a pleasant little gift--or not.
Not sure what the final cost would be but if you can convert your existing setup and add this I would recommend it.. Around here one spring assembly is roughly $45. I had a spring break back about a year ago.. super easy to replace and set the tension. If you did decide to go this route then you will need the twin springs (one on either side of the center mounting. Mine only had one as it is an aluminum door with just a few picture windows.
