Old 08-05-2016, 12:58 PM
bergy's Avatar
bergy bergy is offline
Default Clutch binding
Quick question for you car "doctors". The clutch pedal on my '69 BB Pace Car feels like it is binding upon engagement of the clutch. When I engage the clutch, the pedal feels like it comes up, hesitates, comes up, hesitates, etc. - not a smooth engagement at all. I have rebuilt the Z bar & greased the pivot points. When I push the clutch pedal in, it feels smooth. The "jerking" problem only happens when the engine is running.
My plan is to pull the trans next weekend - thinking that the throw out bearing is binding. Any additional thoughts on the source of the problem would be appreciated. Also, might as well replace the clutch & pressure plate while I'm at it. This isn't a race car (stock 396/325) - recommendations for clutch & pressure plate?
Thanks
Old 08-05-2016, 03:55 PM
Don't forget the Pilot Brg. while swapping clutch parts plus inspect input shaft tip and fit w/ Pilot.
Best check fork condition too also Trans in/out shaft play while all loose on the bench.
Good luck w/ everything!
Old 08-05-2016, 04:50 PM
novadude novadude is offline
Default Re: Clutch binding
As for Clutch/pressure plate recommendations, I really like my Centerforce II pressure plate and disc. Very smooth engagement and great pedal feel. You could also go with a stock parts store replacement, but I think the Centerforce parts are a little higher quality (you do pay for it though). I used an SKF throwout bearing from NAPA (around $30). Much better quality part than what is provided in most clutch kits.
Old 08-05-2016, 10:00 PM
earntaz earntaz is online now
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: PeteLeathersac</div><div class="ubbcode-body">'
</div></div>
X2!!!
Old 08-06-2016, 10:39 AM
bergy's Avatar
Thanks guys!
Old 08-06-2016, 04:19 PM
enio45 enio45 is offline
Check the clutch fork for wear on the inside where the throw-out bearing is placed.
If you can compare the fork to a known good one or new gm one, i have seen them bend - esp anything aftermarket
I would use the over the counter clutch and pressure plate set up from oriellys auto or similar....
Lastly - check that pilot bushing - worth just replacing it if u pull the trans - get the bronze bushing.
One more item, if u resurface the flywheel - have them balance the flywheel and clutch set-up all together....
Eddie M
Camaro-less
87 El Camino SS
Few Ferrari's
Old 08-06-2016, 09:53 PM
AND make sure the throwout bearing is installed correctly on the fork -- don't capture the throwout bearing flange between the rattle clip and fork. Maybe someone here has a good picture on correct installation. TAZ
Old 08-07-2016, 10:47 AM
69L78's Avatar
69L78 69L78 is offline
I just had my M-21 rebuilt at Jody's Transmission's in Reading PA and here are a few things he told me to check before installing. He also has an article coming out in Car Craft about bell housing alignment.
