Old 08-06-2016, 01:06 AM
Default Heavy duty truck 5 speed id
Posted in the lounge instead of technical, as it is so far off topic from muscle car stuff. Anyway, thought someone here could help. After all, you guys know everything, right?
Bought a Chevy engine and trans from BIG chevy grain truck to transplant into my 49 Studebaker farm truck. I think it is a 72 C60. Not sure which 5 speed I got.
Apparently, there were a lot of 5 speeds available back then.
M58 : NEW PROCESS 540GL. 5 SPEED TRANS.
M59 : 5 SPEED CLOSE RATIO TRANS. - NP.
M75 : 5 SPEED NEW PROCESS TRANS
M76 : 5 SPEED CLOSE RATIO TRANS. CLARK
M77 : 5 SPEED TRANS - CLARK
M78 : 5 SPEED TRANS - SPICER
M79 : 5 SPEED CLOSE RATIO TRANS. - SPICER
M85 : SPICER 5752C, 5 SPEED TRANS.
MT8 : SPICER 3152A, 5 SPEED TRANS
MT9 : SPICER 3152F 5 SPEED TRANS
I deleted the 4 speed and 10 speed trans options. I do know this one is a five speed, and it is big. Massive 1.5 inch input shaft.
Truck is being parted out, and is still parked. I am going over there in the morning to get some clutch linkage parts. I know a lot of the 70's chevy trucks have an option sheet taped in the glove box. I am hoping it is still there. I will also get the vin and any data plate info I can. Just need to know what trans I have so I can get some gaskets and seals. Can post some pics tomorrow.
Old 08-06-2016, 02:48 AM
Default Re: Heavy duty truck 5 speed id
I believe it is a new process based on the shift pattern.
Still, there are 3 to choose from.
Old 08-06-2016, 04:29 PM
New Process 542GL.
Don't you wish all the muscle cars had a data plate on the glove box door.
Old 08-06-2016, 08:21 PM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Lynn</div><div class="ubbcode-body">
Don't you wish all the muscle cars had a data plate on the glove box door. </div></div>
Amen to that [img]<<GRAEMLIN_URL>>/headbang.gif[/img] Then we'd have a new hot button item.....&quot;unmolested/survivor glove box door&quot;.
Bill Pritchard
Old 08-06-2016, 09:11 PM
&quot;Glove box lid never been off&quot;... [img]<<GRAEMLIN_URL>>/biggthumpup.gif[/img]
Old 08-09-2016, 06:04 PM
roeville's Avatar
roeville roeville is offline
It's a New Process NP542. The 5 digit casting number on the side of the case would have also identified it. At my old job, we used to sell these for $200-$300 used.
Mike
Old 08-09-2016, 06:10 PM
Yep. Not much market, but perfect for my needs.
Old 08-09-2016, 06:43 PM
all_about_cars's Avatar
all_about_cars all_about_cars is offline
Shows had tachometer,those have good value. Same cluster as C10 you should get that if it not gone
Old 08-10-2016, 01:10 AM
I noticed that after I cleaned up the pic and cropped it. I did not even LOOK at the instrument cluster, even when I was removing the speedo cable (which I left hanging) so I don't know if the tach is still there. It is a good 30 miles away, so don't know that I would make the trip just for that. I can make a phone call and find out.
