Old 10-17-2016, 04:05 PM
m22mike's Avatar
m22mike m22mike is offline
Default Re: '69 brake distribution valve function
Verne
Here is a 70 differential pressure valve. I think 67 through 70 are the same inside, it is just a simple spool valve. You can see the internals here. It can restrict fluid if the spool is shifted from differential pressure, and they can stick. They are not hard to take apart and clean.
Distribution / press diff block
