Old 10-20-2016, 01:59 AM
Default Re: Andy's 66 Caprice LS Conversion Upgrade
Betcha Andy can't wait!!
Old 10-20-2016, 12:55 PM
ImpalaAndy ImpalaAndy is offline
Betcha right!
Old 10-20-2016, 11:33 PM
kwhizz kwhizz is offline
Exhaust is in and the car is back........Another great job by Dave's Mufflers in Kenosha.......James works his magic again
Old 10-21-2016, 12:22 AM
Looks great!
Old 10-22-2016, 02:28 PM
----He is going to waste those tires......Bill S
Old 10-22-2016, 10:46 PM
napa68 napa68 is offline
Those tires may be the only thing to keep that 10 bolt alive [img]<<GRAEMLIN_URL>>/[/img]
Old 10-23-2016, 12:27 AM
Got pretty much all the under hood wiring completed today......went to spin the engine over and found out the neutral safety switch is toast......Andy ordered a new one and that will be his winter project to install it.......LOL....Then we had a major disaster.......added coolant to the Radiator to top it off and come out the next morning and a puddle of coolant under the car......Humm !!!!.......Ended up being a pin hole in the Radiator weld seam..........Sheesh !!!!.......First we had Keith's car dropping dirt all over the place, now we have Andy's &quot;Leakasourus&quot; dumping coolant all over the place.........Time to call the Hazmat team again ............Time to get this &quot;Beater&quot; out of the garage......Andy is coming to drive it home next Saturday...........Put a self tapping screw with a rubber grommet thru the Radiator hole and tightened the screw squishing the rubber grommet to seal the leak till the new Radiator shows up and Andy can replace it at his place.......LOL
Need to hook up the Vacuum line to the Brake Booster and everything else left to do is get all the Dakota Digital gauges and modules installed....Almost done.....Then off to SEMA to Relax.......
Old 10-23-2016, 02:25 PM
Awesome!!! [img]<<GRAEMLIN_URL>>/cool.gif[/img]
Old 10-23-2016, 02:45 PM
Getting started on the &quot;Inside&quot; car stuff this morning.........Got the Gas pedal installed and plugged in.....also took the Dash out to get the Dakota Digital install going......Again.....Look at the Dust on the dash assy.........Sheesh !!!......at least the dust fell inside the car and not on the floor.......
Old 10-23-2016, 03:07 PM
KM265S KM265S is offline
THANK GOD you found some dirt. Now I don't feel so bad.
