Old 12-20-2016, 02:22 PM
69L78's Avatar
69L78 69L78 is offline
Default Re: WHO restores/rebuilds the OEM 3138 HURST Shifters
Yes Pete does nice work, but not cheap, all I was trying to say is for his price you can buy a complete shifter body....not that I am a big fan of Jim at HB
The Following User Says Thank You to 69L78 For This Useful Post:
mhm1966 (09-16-2022)
  #12
Old 12-20-2016, 09:11 PM
Thanks for all the above advice and comments.....I had no idea it would
be so expensive to re-assemble my CLEAN, PLATED parts.
I may (or may not) be able to do this myself, but with no experience
didn't want to struggle with it.
I'll continue to ask my 70' Camaro contacts for further suggestions.
Chuck Sharin
[email protected]
69 Camaro COPO "recreation"
Old 12-20-2016, 09:44 PM
Zman1969 Zman1969 is offline
I took mine completely apart and cleaned and lubed it (didnt want to replate it) and it wasnt bad at all
69 RS/Z 302 VE3 Daytona
69 Chevelle SS 396 375
69 T/A clone LS6/6 speed
90 Formula 350
Old 12-20-2016, 10:14 PM
ban617 ban617 is offline
What about the rubber bushings where the shift rods go in how is that redone ? Will the metal ones found in a Pit Pac fit the levers correctly?
Old 12-20-2016, 10:17 PM
Rebuild kits alone are $100 now days. https://www.hurstshiftersonline.com/prod...hifters-c66.htm
If you want to take yours apart and clean & service it, heres a youtube video to watch first.
https://www.youtube.com/watch?v=bDWB_XIwoak
Old 12-20-2016, 10:22 PM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: ban617</div><div class="ubbcode-body">What about the rubber bushings where the shift rods go in how is that redone ? Will the metal ones found in a Pit Pac fit the levers correctly? </div></div>
Quick link to bushings
https://www.hurstshiftersonline.com/prod...1979-53p386.htm
Old 12-20-2016, 10:24 PM
m22mike's Avatar
m22mike m22mike is offline
Those metal and plastic bushings are for aftermarket shifters with a larger hole.
No one re makes the OEM bonded on seal.
Pete Serio has nice fitting replacement rubbers on his WWW. I think it is presision Pontiac.
His link is posted on pg 1 of this thread.
Mike
Old 12-20-2016, 10:29 PM
Correct Mike.
Link to his website for Chuck and FYI rebuild without plating services is $239. With all new plating services it's $499
http://precisionpontiac.net/Shifter_FAQ.aspx
Bushings are available in his store.
Old 12-21-2016, 03:59 AM
JoeC JoeC is offline
they make a replacement rod bushing for the levers that looks like the original 1969 molded on bushing. They are not molded on but look better then the 1970 and later style replacement rod bushing
also check the springs when rebuilding a shifter as the original springs can get soft after 40 plus years
Old 12-21-2016, 02:47 PM
wundercluck wundercluck is offline
Chuck...My 2 cents...Pete did mine and it was flawless!!
Don
