Old 01-22-2017, 01:20 AM
Alss's Avatar
Alss Alss is offline
Default wire ID
where does this connector go?..double green wire with a resistor?..long lead too. 70 W 30 auto ac car.
thanks
1969 Beaumont 540 th400 3.70
1968 Camaro ragtop LSA ZL1
Old 01-22-2017, 01:26 AM
earntaz earntaz is offline
Default Re: wire ID
Check the A/C compressor ... TAZ
Old 01-22-2017, 01:45 AM
Alss's Avatar
Default Re: wire ID
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: earntaz</div><div class="ubbcode-body">Check the A/C compressor ... TAZ </div></div>
ac compressor is on pass side..this is on drivers rear of motor compartment
Old 01-22-2017, 03:10 AM
Default Re: wire ID
If an A/C car -- was there ever a throttle kicker on the carb?
Old 01-22-2017, 10:56 AM
daverd daverd is offline
Default Re: wire ID
Tcs vacume switch on a bracket passenger
Side of intake manifold ( switch probibly gone)
The vacume part of the switch is plastic
And drys out due to age and engine heat.
Mounted on a bracket that bolts to an intake
Manifold bolt .metal bracket painted engine color.
2017 impala (wife’s car)
Old 01-22-2017, 01:09 PM
Alss's Avatar
Default Re: wire ID
thanks dave!
Old 01-22-2017, 11:16 PM
Default Re: wire ID
Your welcome !
Ask me any questions you need to,
Glad to help .
I restored a1970 w30 hardtop automatic years
Ago .
Old 01-24-2017, 04:26 PM
Alss's Avatar
Default Re: wire ID
since you offered..an pics of the vacumn hoses on the rear of the intake..also coil mounting?..just tying up some loose ends!
thanks!!
Old 01-24-2017, 06:34 PM
Default Re: wire ID
Pics and help on their way Albert [img]<<GRAEMLIN_URL>>/biggthumpup.gif[/img]
Old 01-25-2017, 01:09 AM
Default Re: wire ID
I'll try to find some .my car is a 71 different
Set up ,,and all of the emissions stuff is
Long gone from the car anyway.
