Old 01-12-2017, 02:57 AM
MECTransAm's Avatar
MECTransAm MECTransAm is offline
Default Sun Super Tach SST-802
Does anyone know if the SST-802 will work with a GM HEI....
Old 01-12-2017, 03:22 AM
Default Re: Sun Super Tach SST-802
Yes, I believe it does.
Jason
Old 03-10-2017, 12:51 PM
MECTransAm's Avatar
just to confirm with Jason s (SuperNovaSS) reply,..i talked to a guy at Williamsons Instruments and he says that an HEI ignition ,4 pin module, produces a square wave signal as does the GM standard point ignition, so it will work....i mocked an HEI up on my distributor machine and powered the HEI with 12 volts ,hooked the tach up and RPM readings were the same on the SST-802 and the machine......i hope i phrased that correctly..
Old 03-10-2017, 10:39 PM
JRC99's Avatar
JRC99 JRC99 is offline
The one in our Camaro doesn't read right. I still need to figure out how to fix it.
My cars, passed down by my grandfather:
'68 Camaro SS (454/TH400, possible L78/M22) LeMans Blue, black deluxe interior, black vinyl top. 3.73- mostly Day 2.
'89 Mustang GT- 3.55, subframe connectors, muffler delete, and a couple other minor mods. Exactly as he wanted it, so how it shall stay
Also:
1995 Ford F-150 XL
2004 Dodge Ram Hemi GTX- #192 of 433
Ain't no fun in viewing your car as an 'investment'. Get out there and beat on it!
Old 03-10-2017, 11:13 PM
PxTx's Avatar
PxTx PxTx is offline
I've yet to find a vintage Sun Super Tach that is happy when hooked to an MSD and they are supposed to have a 12v square wave on the tach lead. I will be interested to see if this worKS for you. Please keep us updated.
Paul III
Old 03-11-2017, 12:14 AM
68l30's Avatar
68l30 68l30 is offline
Paul, you need the tach adapter with the MSD and a Sun. I use to run a old Super Tach II .
BIG
Old 03-15-2017, 07:41 AM
JRC99's Avatar
BIG
Know where I could pick one up? I need one too.
Also:
1995 Ford F-150 XL
Old 03-15-2017, 04:30 PM
68l30's Avatar
It's a MSD part..any speed shop should be able to get it. Or online??? I think mine uses the 8920??
BIG
Old 03-15-2017, 08:24 PM
67 Nova Boy's Avatar
BIG
I just called MSD and asked this very question...Tach adapter #8920
http://www.ebay.com/itm/MSD-Performa...hVTX7v&vxp=mtr
Dave
67 Nova Boy
Old 03-15-2017, 10:22 PM
whitetop whitetop is offline
I agree never have I seen one work properly
