Old 04-07-2017, 02:21 AM
70TA 70TA is offline
Default Clutch Chatter
I have a friend that has a 69 396 Chevelle with a 4 speed that has bad clutch chatter. So I replaced clutch and pressure plate and had the flywheel resurfaced. Still had chatter so I replaced flywheel still has chatter and I also replaced motor mounts. I replaced pilot bushing each time. Anyone ever encountered this?
Old 04-07-2017, 03:03 AM
frankk frankk is offline
I am thinking if the trans mount and or if the crossmember were loose could contribute to the condition you are experiencing.
Old 04-07-2017, 03:50 AM
I have had similar problem.....after numerous and multiple attempts with much frustration ....all my problems went away when I replaced my none GM flywheel with new GM flywheel.
Every scenario is different.
Good luck,
Old 04-08-2017, 12:59 AM
luzl78 luzl78 is online now
Bad ujoints?
Old 04-08-2017, 03:15 AM
earntaz earntaz is offline
If the bellhousing is not in absolute perfect alignment -- clutch chatter may result. If push gets to shove ... change the bellhousing. TAZ
Old 04-08-2017, 10:22 AM
I checked u joints, I wondered about bell housing but it's the original one and if it's off it would when car was new this is a 55,000 mile car.
Old 04-08-2017, 10:39 AM
Rixls6 Rixls6 is offline
Had the same problem with a 69 Chevelle I owned.
The new owner bought it knowing that it had clutch chatter, then chased the problem in a similar fashion as you.
One thing that helped was to replace all the rear control arm bushings.
Not sure if anything else was done after that.
Rick
69 Chevelle SS396 Silver L78 M21 Post Sedan (Berger Chev.)
69 Chevelle SS396 Black L78 4-speed 4.10 Post Sedan
Don't text and drive.
Somebody's life may depend on it!
Old 04-08-2017, 11:09 AM
Rick,
I still think the problem exists :-(
Old 04-08-2017, 01:45 PM
69 Post Sedan's Avatar
What clutch disc are you using?
Also, you may need to center up the bellhousing with offset dowl pins. It can be time consuming but well worth the effort.
1968 Schwinn Orange Krate
1969 Schwinn Pea Picker
1968 Schwinn 5-Speed
1970 Schwinn 3-Speed Deluxe
1973 Schwinn 5-Speed Suburban
All Original Paint Bikes
Old 04-08-2017, 03:11 PM
galveston's Avatar
galveston galveston is offline
Originally Posted by Postsedan View Post
Rick,
It's my understanding that the problem was resolved and has not reoccurred but I'm sure Bill could update us if anything has changed.
Shaun
