Old 04-28-2017, 12:09 PM
KM265S KM265S is offline
Ken, any possibility that wildwood sent you the wrong stuff? Just sayin', it happens. Even though it wasn't the greatest setup, the cpp stuff fit. Damn beater issues.
Old 04-28-2017, 06:59 PM
kwhizz kwhizz is offline
Nope !!!......They sent the correct parts for a 12 bolt with stock axle bearings.....The mounting of the Wilwood system is completely different than the "Floating" CPP set-up......Just got the bad Luck of the draw when I bought the housing.......
Ken
Old 04-29-2017, 02:31 PM
300deluxeL79's Avatar
300deluxeL79 300deluxeL79 is offline
ken, pretty sure all the '65-'70 b-body 12 bolts used the larger bearings
Old 05-01-2017, 08:27 PM
Found out today that the Big Bearing rears were installed in Impala Station Wagons.......And I thought I knew everything.............LOL.....Like I said before......This car stuff is Hard !!!!!!!
Old 05-02-2017, 08:53 PM
Got it figured out today.........The 66 Impala Wagon rear axle assy with the big bearings has the same Housing Tube dia ,Flange bolt pattern and Axle / Flange spacing as the 59-64 Impala axle assy...........Ordered the correct kit today........Learn something every day
Ken
Old 05-06-2017, 01:18 PM
Got the new kit and got it installed.....I couldn't find any documented info on these big bearing rear ends, but........I bought the 59-64 Impala kit and everything was perfect.....bolt pattern.......Perfect!!!......Axle offset.....Perfect!!!.......E-Brake......Perfect !!!!.........LOL........Not cheap but worth every penny.........I also couldn't find and stamping on the rear either.......Hummmmm!!!!.....I also had to order the Wilwood E-Brake cable kit as what I had wouldn't work.......
Old 05-06-2017, 01:40 PM
CC Rider's Avatar
CC Rider CC Rider is offline
Looks like a cool set up.
Rick
1966 Chevy Caprice 427-390
Old 05-06-2017, 04:08 PM
"Got it figured out" guy!
Old 05-06-2017, 11:51 PM
NICE !!! Back in the day when we worked on our cars it was a hundred bucks here and a hundred bucks there and to us that was a lot of money. We worked hard to come up with that money. Now today it's a thousand bucks here and a thousand bucks there. Lots more pennies.
Old 05-07-2017, 11:09 AM
Yep !!!!.........And again.......I found out that I can't afford "Cheap" Stuff !!!!!!!
