#711
RXT clutch is in. All the gory details of the install are on my FB page.
Test drive report soon. |
#712
Best wishes Eric!!
Sam... ![]() |
The Following User Says Thank You to mockingbird812 For This Useful Post: | ||
VintageMusclecar (05-16-2017) |
#713
The first test drive is in the bag--just a brief jaunt around the neighborhood, stayed close to home "just in case", but so far, so good.
The pedal effort is very comfortable, and as far as "driveability", I can already state that this is by far the most street-friendly clutch I've had in the car so far. Zero chatter, even in reverse, very easy to--for lack of better term--ride, not like the previous race clutches which were (to varying degrees) more like an "on/off' switch. I didn't lean on it at all, so as far as holding power goes, the verdict's still out on that. However, should this clutch perform as advertised, I will officially consider myself a McLeod convert. More soon--weather permitting. |
#714
Keep your fingers crossed Eric -- sounds like you finally hit the right combination ... Craig
#715
Sounds awesome Eric. I hope it will handle the power.
Jason |
#716
Clutch update:
It holds. ![]() ![]() ![]() ![]() |
#717
Yee haw!!!
Sam... ![]() |
#718
Congratulations!
#719
This clutch definitely hits harder than its predecessors.
Gonn'a have to watch it pounding it on the shifts--that poor 12 bolt's already hacked out parts once. ![]() |
#720
Pretty sure the Legend trans in the Chevelle is on it's way out. It's making some very unhappy noises and there's a new driveline vibration that definitely isn't engine related. Not sure where I'm going to go from here.
