Old 05-28-2017, 01:38 PM
Crush Crush is offline
Clearly I'm missing something. So I take the 3 Phillips from the bottom but I can't get to the 2 screws behind plastic back seat button that's clipped in. I'm using trim tools to push on clips and pry and it won't release. Does the long strap that locks the seat back need to have those bolts removed?
Btw I'm in search of a build sheet... any clues where it might be? Did all 69 novas get one?
Old 05-28-2017, 02:49 PM
WILMASBOYL78's Avatar
Default build sheets..
The Fisher Body "build sheet" is typically found in the rear seatback...most often on the passenger side. I have found them in other spots like the seat bottom [both front and rear].
On rare occasions paperwork can be found up under the dashboard...stuffed behind the radio/glove box area...on some Novas, I have found trim cards under the carpeting.
In all cases, use caution as the paperwork may be brittle...take your time removing it, especially if it is attached to the springs of the seats.
Good luck..wilma
02 Berger 380hp #95
Lots of L78 Novas
Join National Nostalgic Nova!
70 Orange Cooler
69 Camaro
Old 05-28-2017, 02:57 PM
Thx Tom
Is it possible that some did not get any paperwork stuffed in them?
Old 05-28-2017, 03:13 PM
One other question could it be under burlap ?
Old 05-28-2017, 05:52 PM
Post paperwork...
Unlikely it will be under burlap...the seat components were staged for the assembly line...workers referenced the Fisher Body sheets and pulled the correct color/trim level items. Sometimes you will find multiple sheets in the same car...sometimes the document will be for another car. Since std. black interiors were so common, you often see this with these components.
Many times the paperwork was simply discarded...back then those boys never thought we would be looking for these documents.
The body sequence number on the Fisher Body sheet should match the cowl tag.
-wilma
02 Berger 380hp #95
Lots of L78 Novas
70 Orange Cooler
69 Camaro
