Old 07-04-2017, 05:07 PM
This was the first rear end under the car. The housing is from a '64 Galaxy, the nodular case, Daytona pinion housing and Detroit Locker are from a '69 Mach 1, the axles are from a '65 Galaxy, the 4.11 gears are from a F150 and the disc brakes are from a Lincoln Mark 5. I had to use what I could find due to lack of money. Some of you might notice that I had the ladder bars upside down. I was still learning.
This is the first time the engine was assembled. The block is one of the first Bowtie blocks, the crank is from a L78, the rods are LS6 and the pistons are TRW.
The heads are 3rd design GM aluminum D ports. The cam was a Comp Cams solid roller, rockers are Comp Cams and the stud girdle is an old Jomar. The engine has been apart many times since then. This was the first of 4 cams that have been in the engine.
