  #11
Old 07-13-2017, 01:06 PM
HawkX66's Avatar
HawkX66 HawkX66 is offline
Originally Posted by earntaz View Post
Advertise it on CL or EB ... someone out there may need it ... TAZ
I will at some point. Too many irons in the fire right now...
Originally Posted by WILMASBOYL78 View Post
If you have a later block it might be a good choice to consider...the early heads have some limitations...but they will help keep the compression ratio up with those small bath tub chambers.
Ditch the carb and get a regular Holley VS unit...there are plenty of them around.
If you are looking for some professional guidance, I would call Eric Jackson at Vintage...he can provide excellent engine advise, parts and tech....and also help you in the carburetor dept...well worth the call.
-wilma
Putting that carb on it wasn't a consideration. It was just laying on top of the motor when I bought it so they threw it in the deal. I have quite a few carbs in the garage. One is a nice Holley 3310 750cfm that I rebuilt last year for my other motor. She should do just fine. You're right about Eric though. Top notch. Thanks.
I'm leaning more towards the 72 block with the 65 heads. I just think all the little differences in the 65 block wouldn't be worth it for the extra compression that I'm now finding out I might not want. I'm not too worried about the limitations of the heads. I just want a good, reliable power plant that I can cruise and WILL get out of it's own way when I want it too.
-Dave
Semper Fi!
69 Camaro SS396 L34 X66
