Old 08-10-2017, 07:22 PM
bbbenny bbbenny is offline
Thumbs up
Jason, Your work speaks for it;s self! Quality and Detail!! BBBenny
Thanks Benny
Enjoy; orginal cars,with orginal drivetrains and docs. bblocks are my favorite.
Old 09-11-2017, 11:19 AM
jasonL78 jasonL78 is offline
It has been about a month since my last post. Frame is completely assembled and ready for the body. Once back together I will start the front end body work and get some color on it. It's coming along. I feel I have worked out all the problems the last body shop created for me hopefully its smooth sailing from here on out! Not a concourse frame the owner will be driving this car. I feel it cleaned up nicely.
Looking for the next project.
Old 09-11-2017, 12:20 PM
cook_dw's Avatar
cook_dw cook_dw is offline
Lookin' good. Patiently waiting on more progress.
Old 09-11-2017, 07:19 PM
Jason, Suggesting you use SPI Epoxy Prime shipped directly to your address for a little
over $220 for two gallons of working material (1:1)
I also used PPG Delfleet Essential Black (flattened with DX10) to paint frame, etc etc
as I saw Scott Tieman and Nile Wing's shop use
Chuck Sharin
[email protected]
69 Camaro COPO "recreation"
Old 09-12-2017, 11:21 AM
SPI EPOXY requires you to have your shop at 70 degrees for 24 hours. During the winter I would have a problem with this requirement. I use OMNI epoxy and high build primer. Its about the same price for 2 workable gallons.
Old 09-14-2017, 11:08 AM
Time to start mocking up the front nose.
Old 09-26-2017, 01:14 AM
First round of test fitting the new sheet metal. Overall fitment is OK, but you know all this aftermarket sheet metal needs rework to get all the body lines to line up. The hood actually fit real nice it was the fenders I will have to rework. The door to fender radius is way off you can see this in the one picture and when I fixed it. I had to drill all the spot welds along the fender edge relief cut the sheet metal, pull it out, and re-weld.
Now when the rubber nose was on the car the top edge of the fender was way to high but was fine at the hood edge. I had to drill out all the spot welds along the front of the fender and push the top edge down and re-weld it to the inner frame of the fender. One fender completed in just about 6 hours. Lots of test fitting to get the fender to line up.
Old 09-26-2017, 01:49 AM
David C. David C. is offline
Looking really good, your doing a great job! Reminds me of a Camaro convertible I got from another shop. Previous shop drilled holes in a new complete trunk pan assembly, but did not clamp it down to frame rails. They ended up welding the holes shut, but leaving a gap covered with seam sealer!
Dave C.
Old 10-10-2017, 11:11 AM
I know they didn't fit this good from the factory but you know me I just couldn't leave it alone. Front sheet metal is all test fitted. Just have to finish this rubber nose lots of digs and scratches to fix.
Old 10-13-2017, 04:32 PM
Lots of work to get this nose straight again. I'm priming the front end this weekend!
