Old 10-29-2017, 05:23 PM
Viz Viz is offline
I can only tell you what my 69 Chevelle build sheet shows, I don't know if it would match up to Camaro build sheets.
I bought it new, small block 350, so I know it all matches the build sheet. Box 28 on the tank build sheet is XG, and the transmission option list on the sheet shows M20 4 Speed Trans. I assume it is the wide ratio.
Viz
