Old 12-03-2017, 02:18 AM
69novamanrick 69novamanrick is offline
Does anyone have any pics you can post of the mounting bolts and spacer for the support assembly 3946017? This mounts to the front hole of the driver exhaust manifold and the hole in the block just below the exhaust manifold? The bolts that I have are a matched set for the manifolds, but there's no longer bolt in this set to accommodate the thickness of the bracket and spacer that's mounted to the front hole of the exhaust manifold. The assembly manual shows a spacer and a longer bolt, but Id like to know the size and dimensions like the thickness of the spacer and length of the bolt. Thanks!
