Old 12-04-2017, 04:57 PM
Keith Seymore's Avatar
Originally Posted by Nasblu View Post
Few more 1970 Monte Carlo from Flint Assembly Plant
My alma mater.
I don't see anybody I know...
K
'63 LeMans Convertible
'63 Grand Prix
Old 12-04-2017, 05:01 PM
Also notice in the body drop picture of the blue Monte Carlo the driveshaft dampner attached to front yolk looks like a harmonic balancer only smaller. Also on the Cranberry Red body drop picture looks like the car has redline tires which I have never seen before on any of the 1970 Monte Carlo built sheet I have ever seen.
Good eye.
You may already know but that is to control rear axle whine (as a result of "non conjugal meshing action" of the ring an pinion). The resulting disturbance is transmitted up the driveshaft, causing it to wind up and relax like a rubber band, the order of the disturbance being commensurate with the number of teeth on the pinion gear. The damper is tuned to attack the resonant frequency of the shaft. You can put them on the rear axle companion flange as well, but they are not as effective because the amplitude of the disturbance is bigger the farther forward you go.
We used a lot of those on the old Astro/Safari vans, and on GMT400 pickups with the aluminum one piece shafts.
K
'63 Grand Prix
Nasblu (12-04-2017)
  #23
Old 12-04-2017, 05:08 PM
Originally Posted by StealthBird View Post
I'm not sure what the guide plates (if that's what those are) actually do during the hood installation step? Anyone know?
I've never seen anything like that before. I suspect they guide the hood into place, but also hold it open in position while driving the attaching bolts. That way you can release the hoist and let it go back to pick up the next job.
K
'63 Grand Prix
Old 12-04-2017, 05:14 PM
flyingn's Avatar
flyingn flyingn is offline
how about the guy under the orange one with a cigarette hanging out out his mouth?
Frank Szymkowski
Old 12-04-2017, 05:58 PM
StealthBird StealthBird is offline
I just found this b&w shot in my files. Those shelving units must have been enormously strong to hold 6 complete engines at one time, but imagine the load that must be on those bottom units that are supporting 6 engines, stacked 5 high?
1959-1980 Pontiac Window Sticker Reproductions : PontiacWindowStickers.com
DVD's for Musclecar fans! MusclecarFilms.com
Old 12-04-2017, 06:07 PM
Nasblu's Avatar
Nasblu Nasblu is offline
Originally Posted by Keith Seymore View Post
Good eye.
K
I had a feeling that was its intended purpose but was never 100%. Thanks for for the explanation.
Old 12-04-2017, 06:28 PM
Nasblu's Avatar
More Flint Production.
Old 12-04-2017, 07:38 PM
That guy looks like he just walked in off the street.
Short sleeve shirt,no safety glasses,loose fitting casual pants,soft toed shoes and is he even wearing socks?
Old 12-04-2017, 07:52 PM
earntaz earntaz is offline
I think OSHA was a toothless tiger back then ...
Old 12-04-2017, 08:55 PM
Crush Crush is offline
He’s an engineer...
