Old 12-06-2017, 07:55 PM
RAII4speed RAII4speed is offline
Default Correct color 1969 350 oil dip stick
I am detailing my engine and I would like to know the Factory correct color of the dip stick and the dip stick tube ...1969 350 CID
I don't hate the rich, And I don't pitty the poor
Attachments - The Supercar Registry 1969 Camaro SS 350 (Throttle Rod Pic 2) (2).jpg 047 (2).JPG
Old 12-06-2017, 08:06 PM
William William is offline
Was not painted.
Old 12-06-2017, 08:07 PM
Raw steel ???
Old 12-06-2017, 09:07 PM
Could be there was some plating on them, not obvious whatever it was. Or, just a better grade of steel.
Old 12-07-2017, 07:05 PM
Natural steel, no paint at all...
Old 12-07-2017, 07:43 PM
bbbentley's Avatar
There was enough oil leaking out of the valve cover by 30k miles, that the tube/ dipstick stayed shiny immersed under an oil bath mixed with road crud and, walah! Lifelong metal preserver....those engineers thought of everything
FULL OWNER HISTORY
Old 12-08-2017, 02:54 AM
L16pilot L16pilot is offline
IIRC, the SBC dip stick tubes were installed at the car assembly plant, not the engine plant. Not sure in '69, but in 1970, I've seen dip stick tubes from Van Nuys painted black, (Charley's former 1100 Mile 70 Z28). Is this a case where the answer could vary depending on the assembly plant?
Steve Nuwer
1970 Z28, Norwood 03A, 48 48, 723 Int, M20, COO, 2021 Legends Platinum restored
1970 L78, Norwood 04C, 17 17, 711 Int, M21, COO, born-with drivetrain project.
1972 Z28, Norwood 11C project, born-with drivetrain, 26 26, 775, M20, CGG project
1970 Z28, Norwood 05C, 48 G, 720 Int, M21, COZ, Original Unrestored (SOLD)
www.2ndGenZ.com
Old 12-08-2017, 08:34 PM
natural metal.
Old 12-09-2017, 01:28 AM
69VN's Avatar
69VN 69VN is offline
I believe there were two available for the 1969 SS350 engine and the Z/28. One had the green tip dipstick and the other had a flat tip dipstick resembling the number 9. See pics
below...
Sal
I currently own a 1969 Camaro SS350. Although the original drivetrain is long gone, this 4/speed car has a March '69 HC coded block with #041 heads. The transmission is an M20 Muncie #660 case and the rearend is a BS coded 12 bolt posi. Built in Van Nuys.
