Old 01-05-2018, 02:04 AM
enio45 enio45 is online now
Default 69 Camaro 12 bolt Carrier Posi
Are all gm 12 bolt posi carriers the same? Are they interchangeable?
Meaning, is a 69 chevelle carrier interchange with camaro?
I have a client who wants to go from his 4:10 gear ratio to a 3:73 ratio.
I'll need to swap out the carrier and ring and pinion and I need to know
what interchanges with what , in other similar GM vehicles.
On a second questions, what would a 3 series carrier posi and ring & pinion cost if
i bought a good used replacement?
Thanks for the advise
Eddie M
Camaro-less
87 El Camino SS
Few Ferrari's
Old 01-05-2018, 02:21 AM
Ed, yes ring, pinion and the carrier are the same Chevelle Nova Camaro you can also leave the 4 Series carrier and put the special ring gear for the 373 gears that is designed to be used with the 4-series carrier
67 Z/28 Butternut Yellow
69 Z/28 Rally Green
69 Z11 Pace Car
2010 2SS RS Aqua Blue
68 Z/28 Lemans Blue
C7 Corvette
68 SS Lemans Blue
Old 01-05-2018, 02:30 AM
68camaroz28 68camaroz28 is online now
Originally Posted by luv2sixty9 View Post
Ed, leave the 4 Series carrier and put the special ring gear for the 373 gears that is designed to be used with the 4-series carrier
X2 as I'm doing that with one of our cars this spring. Makes for a much easier and simpler swap.
68,69&2015 Z/28's
Few Corvettes
Old 01-05-2018, 02:32 AM
L78 Fred L78 Fred is offline
Eddie,
If you are looking for a 3 series posi - call or text me
Just sold a complete 3 series posi/308 rear that I have had for 30 years to member of the site who just changed the center section to go racing and would like to sell it
Best wishes
Fred
Fred
[email protected]
610-585-4155
WANTED:
1969 396/375 hp JH Vin N6352xx Mid April 69 block 272 casting
Always looking for dated L78 parts from Jan-Apr 69
Old 01-05-2018, 02:44 AM
X66 714's Avatar
X66 714 X66 714 is offline
Fred
If Eddie isn't interested, I might be
Thank you, Joe
Old 01-05-2018, 04:44 AM
All of the Chevy car 12 bolt differentials and gears will swap. The truck 12 bolt is different and the car differential and gears will not swap with the car 12 bolt.
Before you remove any gears or parts be sure that you do a pattern check and measure the backlash. Take pictures of the drive and coast pattern so that you will know how to set the gears when you install them in another housing. You will have to shim the pinion and set the backlash and bearing preload all over again when you swap the parts from one housing to another.
Old 01-05-2018, 10:16 AM
bbbentley's Avatar
I have a 3 series and want to go 4.10, would like at least the 4.10 gear, but prefer to have 4 series carrier if someone wants the 3 series? I may even settle for a 3.73 R&P. also have an April BV if someone is in need? Hate to rob the pieces out of the BV.
Not to hijack, but need camaro nova axles any brand stock spline count and cheap.
FULL OWNER HISTORY
Old 01-06-2018, 02:49 PM
WILMASBOYL78's Avatar
WILMASBOYL78 WILMASBOYL78 is online now
Default 4.10 gears and carrier..
PM sent...
-wilma
02 Berger 380hp #95
Lots of L78 Novas
Join National Nostalgic Nova!
70 Orange Cooler
69 Camaro
