Old 01-06-2018, 03:46 AM
Billohio Billohio is online now
Thanks Mike I bet that would work
Bill
Old 01-06-2018, 04:03 AM
Formica (yes the laminate co) also make a good quality contact adhesive. I've used it for many yrs on counter tops and also many times when contact adhesive is needed with the car resto's. It can also be sprayed, brushed, or rolled on.
69 El Camino
69 Nova
C7 Vette
Old 01-06-2018, 04:43 PM
SS427's Avatar
SS427 SS427 is offline
Which adhesive used depends on the type of material you are gluing. Vinyl top, headliner, foam, etc. We also use the Dap adhesive for headliners as it is readily available and have had good luck with it. My past upholsterer used a different commercial grade gun adhesive but I do not recall what it was. The 3M77 and/or 3M90 spray can adhesives are so so for the home DIY'er but I have to order 3M90 as no one carries it around here. However and again I do not suggest using it if you can avoid it as long term can be an issue.
Rick Nelson
The Following User Says Thank You to SS427 For This Useful Post:
Billohio (01-06-2018)
  #14
Old 02-18-2018, 12:23 PM
BillD BillD is offline
Originally Posted by BillD View Post
I am putting some vintage stickers and decals on the inside of my trunk lid. The old water slide decals I can work with. I also have a few adhesive backed items that have at least partially dried out. Does anyone know of a good adhesive (spray?)that would work for the stickers?.
This is one of the stickers I am working with. Some of the adhesive is dried up and some of it is still a little sticky
For anyone interested, I ended up heating the sticker with a hair dryer put it in place and continued heating it and it stuck like new. Thanks for all the help
The Following User Says Thank You to BillD For This Useful Post:
RobR (02-18-2018)
  #15
Old 02-18-2018, 02:09 PM
perfect Bill. Great idea!
Old 02-18-2018, 09:40 PM
McCune McCune is offline
This 3M transfer tape is what you use to make stickers like new again. https://www.amazon.com/3M-Adhesive-T.../dp/B00P26Z04I
Old 02-19-2018, 04:59 PM
Jonesy's Avatar
Jonesy Jonesy is offline
I tried to reglue my sagging headliner in my 79 z/28 with 3M 77 spray glue. It lasted about 2 months and now its fallen back down.
Old 02-19-2018, 05:44 PM
Lynn Lynn is online now
So, on a sagging headliner (one piece, early 90's car), I am guessing the best way to remedy is to remove the whole lining and spray new adhesive.
What would be the adhesive of choice? I don't think the contact cement would work, as it would bleed through the material.
Old 02-19-2018, 08:11 PM
m22mike's Avatar
m22mike m22mike is offline
Lynn
Go back to post #10 in this thread. The rattle can glue has very limited usage as noted already.
Mike
Old 02-19-2018, 08:27 PM
Mike: Wouldn't that bleed through the thin fabric?
