  #11
Old 01-09-2018, 08:58 PM
RAII4speed RAII4speed is offline
Originally Posted by Jonesy View Post
Looks like his negative cable goes to the thermostat bolt which is correct.
Those PBT stamps were used at Norwood, so those would not be correct.
Looks like your brake booster hose is too long so cut it shorter.
Should be a clip on the top of the alt bracket for the neg wire??
That old pic really shows alot!!
I believe the hose from the power booster is the original one, I will check for markings on it.
YES the clip on the alt bracket is missing whereas the alt bracket was repainted. I did buy one for it and will install it. ALSO, there is no bracket that holds the heater hoses to the alt....I also bought one of those. Should it have one? I do not see one in the original picture BUT I have seen them on original cars ANYONE know?
THANKS
I don't hate the rich, And I don't pitty the poor
