Old 02-27-2018, 02:32 AM
Lynn Lynn is online now
Default Graphite Grease on Head gasket?
I should FINALLY be able to assemble my 1.1 Opel GT engine tomorrow evening.
Reading up on the assembly procedure, the shop manual calls for coating the head gasket on both sides with graphite grease. I was thinking I would just spray both sides with Copper Coat.
Strangely, the same shop manual does NOT call for graphite grease on the head gasket of the 1.9 engine. Hmmm. Research indicates that the grease is not intended to help it seal, but intended to make it compress more easily. The 1.9 head bolts torque at 72 ft. lb., but the 1.1 head bolts torque at only 35. Never seen a head bolt torque that low. It is not a mis print, as I checked three sources, and they are all the same.
I think I am going to follow the procedure, but was wondering if anyone had any experience with any other odd little engines that called for graphite grease on the head gasket. If so, has that procedure been updated since 1969?
Old 02-27-2018, 03:54 AM
VintageMusclecar's Avatar
Are the head gaskets OEM?
If not, what does the manufacturer recommend for torque?
Old 02-27-2018, 04:05 AM
Oem.
Old 02-27-2018, 12:24 PM
L78steve L78steve is offline
Could it be to allow the head to expand and contract?
Old 02-27-2018, 12:32 PM
I'd be worried of any Graphite entering the oiling system and do something different.
Cool on the Opel and hope to see more of it!
Old 02-27-2018, 12:47 PM
With the hp that thing is going to make you can probably just duct tape the head on.
Old 02-27-2018, 02:43 PM
I tried this once. It works good until the head gets hot and melts the tape.
Old 02-28-2018, 04:41 AM
OK, make fun of my little one lung putt putt car.
Went ahead and covered it in graphite grease. What a mess. Did my best to keep it out of the cylinders, but assume it will burn off on the first start.
Will let you know if the duct tape lets loose.
Old 02-28-2018, 01:53 PM
Billohio Billohio is online now
alot of good advice here Lynn. Thats why I check daily, hate to miss something I need to know!!
Bill
Old 02-28-2018, 02:58 PM
Unreal Unreal is offline
The graphite will not burn off until at least 1500*F, so it will clear out of the combustion chamber, but will remain on the head gasket.
