Old 03-26-2018, 06:58 PM
Question Is This An Accurate Production Number?
1 of 58 COPO Camaros produced with Rally Sport option in 1969
https://www.mecum.com/lots/SC0518-32...opo-camaro-rs/
Old 03-26-2018, 09:21 PM
m22mike's Avatar
m22mike m22mike is offline
I say NO. ON ZL1 they know. But those type numbers were not tracked on others models. The RS option alone was. most likely just auction hype ?
Old 03-26-2018, 10:09 PM
They usually start a bogus claim like that to make others talk about it on websites.
...it worked.
Old 03-26-2018, 10:22 PM
I thought the '69 RS COPO Camaro's had a Camaro fender emblem?
- Warren
Old 03-26-2018, 10:23 PM
m22mike's Avatar
It might be one of a bunch with crappie front springs.
Old 03-26-2018, 10:26 PM
bigsixman bigsixman is offline
- Warren
You are correct on the fender emblems. There are other items incorrect on this car also.
69 camaro X11, 56,000 miles, original HO paint
67 camaro SS/RS, Butternut yellow, bench, fold down
Old 03-26-2018, 10:34 PM
m22mike's Avatar
- Warren
http://www.camaros.org/copo.shtml
Check out the 5th paragraph in the " application to the Camaro chassis " through June they Recieved the Camaro script.
Old 03-26-2018, 10:51 PM
Check out the 5th paragraph in the " application to the Camaro chassis " prior to June they Recieved the Camaro script.
Mike, do you have that before and after June info turned around?
I have not seen a RS COPO with the Rally Sport emblems on the front fender. A friend of mine has an original 06A build RS COPO 9561 with the Camaro emblems on the fenders.
I know better than to say never, but that info is new to me.
Old 03-26-2018, 11:18 PM
m22mike's Avatar
I edited my post to read....through June....they got the Camaro script.
Old 03-26-2018, 11:42 PM
William William is offline
The Camaro emblems on RS COPOs extended to early July '69 at least.
The Mecum COPO [N624797] probably should have Camaro fender emblems.
At this time, no one knows how many RS 9561 COPOs were built.
The Following User Says Thank You to William For This Useful Post:
m22mike (03-27-2018)
