Old 03-28-2018, 04:06 AM
Lynn Lynn is online now
Default Product Review. Small Body HEI
A while back, I posted about an HEI problem I was having with the El Camino. I ended by saying I was going to pirate the large body HEI distributor out of my Studebaker farm truck when I replaced it with a small body. The farm truck distributor works great, but rubs on the firewall.
So, went shopping for a small body distributor. Found one on ebay for $39.99. Too good to be true? Yes.
Item was described as:
Brand: A-TEAM PERFORMANCE Surface Finish: Red
Manufacturer Part Number: R2R6701R Warranty: Yes
Interchange Part Number: PE323R UPC: Does Not Apply
Other Part Number: Ready To Run Electronic
Got the distributor, and was very impressed with the machining of the body. Uses a GM type module. Very little slack up and down with the shaft. Put it on the distributor machine and for ran it at 500 rpm (which would be 1000 crank rpm if in the car). Started to increase the rpm and it started retarding the timing at 1000 rpm (2000 crank). Wait a minute, what did I do wrong? Nothing! Ran it multiple times and got the same result every time. It did finally start advancing, but not until 1200 or so, and then advanced so slowly, it did not reach full advance until 3000 distributor rpm (6000 at the crank). Totally unacceptable.
I thought maybe just remove one of the springs and see if it advanced a little quicker, but wanted to investigate the retard issue. I wasn't seeing things. Took it over the the bench and discovered that the reluctor wheel (if that is what you call it) turns a few degrees on the shaft. Even though they did a great job machining the body, they did not take the same care machining the groove in the shaft where the wheel sits. Pics attached. You can see how I am rotating the wheel, but the shaft does not move in those two pics.
The auction will be gone soon, so I tried to post a screen shot. Would not post. Item is 262465384326.
I am sending the distributor back. It is a shame. Had they spent just a day sorting out the machining of the shaft (one groove) and working out a decent curve, this would have been a winner.
Now the question is: where to get a decent small body hei for the truck. I have an unused msd 6AL set up, but that is overkill for this truck. Could put points distributor in it, but then have to run a resistor, and run a wire from the starter so it gets a full 12 volts. Would rather just buy a small body hei, curve it, stab it and go.
VintageMusclecar (03-28-2018)
Old 03-28-2018, 05:05 AM
hogdaddy hogdaddy is offline
This looks promising. http://performancedistributors.com/p...nition-system/
Old 03-28-2018, 06:37 AM
Lynn, Have you investigated/read on the private label JEG's or Summitt HEI distributors
as I also need one for my 73 project.
Chuck Sharin
[email protected]
69 Camaro COPO "recreation"
Old 03-28-2018, 12:19 PM
VintageMusclecar's Avatar
Grab a decent used points distributor and stab this in it:
http://www.fuelairspark.com/fas/xr-i...licationshtml/
(It's the old Crane conversion. Yes, sadly now Crane is owned by COMP--but at least they're still in business)
I run this on my Chevelle, works mint. Just make sure to wire it up correctly--it's easy to zap it if you don't. Don't ask me how I know.
Anyhow--with this, you retain GM parts availability, and should the distributor itself ever crap the bed, just grab another one and swap the guts into it. Easy-peasey.
Old 03-28-2018, 01:06 PM
Eric: And with the XR-1, can I run a straight 12 volts full time?
Old 03-28-2018, 02:05 PM
I think I got my answer. Catalogue pays says operating range 8 - 18 v.
Old 03-28-2018, 02:15 PM
bbbentley's Avatar
Stock GM dizzy with petronix igniter III
FULL OWNER HISTORY
Old 03-28-2018, 02:42 PM
Jonesy's Avatar
Jonesy Jonesy is offline
Here is the auction with the distributor Lynn bought
https://www.ebay.com/itm/SBC-BBC-Sma...ZXRjlg&vxp=mtr
Dave Ray converts your existing points distributor over to HEI. I have heard good things about these.
http://www.davessmallbodyheis.com/
Old 03-28-2018, 02:57 PM
tjs44 tjs44 is offline
Dave does a great job!Tom
Old 03-28-2018, 03:13 PM
I agree about Dave Ray. If this was a high dollar vehicle, would use him. This is my farm truck.
