Old 08-03-2018, 06:31 PM
x33rs x33rs is offline
I like those factory cams mentioned but there is power to be found. I like to build PS engines and then skirt with the rules. Camshaft is one area I find power with even just a little bit of wiggle room. Since you're playing without rules I'd go roller for sure and enjoy all the benefits.
On my DZ I built the 302 per the PS rules, which state duration @.050 within 1% and lift at the valve within 2% of advertised. To take advantage of this with the solid cam I employed some knowledge of a good friend/engine builder that knew what would work well with stock unported heads.
Stock lift is advertised .485 but when you figure lash at .030 lift is only .455 so we changed the lobe profile to .495" lift with tight lash of .014" so lift at the valve falls in at .481", moved the duration a pinch and put the lobe sep where he felt would work best with the manifolds and exhaust system being used. A little trickery with the cam but within the rules. I kept compression at a true 11:1 (didn't use the 1.5 allowance) so the engine would be happy on pump gas. I'll assume that is also one of your requirements. Keeping iron heads and 11:1 requires attention paid to off seat timing and intake valve events.
The result was 402 hp on the dyno at 6700 and held pretty flat to 7200 on 91 octane.
Here's a quick idle clip. Makes 9 inches of vacuum up here at 5,000 ft. and more like 13 inches at sea level, very docile to drive, wife daily drives it, and it knocked down 17 mpg on the last highway trip we made, with an M-20 and 3.55's. It would run AC fine, if these cars had AC that is.
https://youtu.be/IZ0HlEY7b74
Here's a driving clip shifting at 7,000 at about 1:20 in. I like the cam, it works well with the 3.55's and the 4.88's. Nice smooth endless power band but if I were you and not worried about rules, I would have went a completely different direction.
https://youtu.be/5vX6hVQ_cKw
The Following User Says Thank You to x33rs For This Useful Post:
aaronkl84corvett (08-09-2018)
