Old 08-28-2018, 02:58 AM
I've had a vintage Lakewood block plate and a couple modern versions and none were painted, simply raw iron.
Old 08-28-2018, 11:52 AM
OK, I was thinking that they were black.
Old 08-28-2018, 02:38 PM
Based on the shape and round flange, I believe that is a Ansen unit.
Jason
68 DANA (09-02-2018)
  #24
Old 08-31-2018, 04:01 AM
Bernhard Bernhard is offline
I just picked up a nos Lakewood bellhousing with block plate and the block plate was bare metal.
69 442 post bench 3 pedal
The Following User Says Thank You to Bernhard For This Useful Post:
big gear head (08-31-2018)
  #25
Old 09-02-2018, 02:34 PM
wheelhop wheelhop is offline
How about some pics? How old is the bellhousing?
Old 09-02-2018, 03:07 PM
68 DANA's Avatar
68 DANA 68 DANA is offline
Yes, the scattershield in question is manufactured by Ansen. Here is a picture of the scattershield in a 1970 Ansen Hi-Performance Catalog and this style of unit maybe in the older catalogs as well.
Old 09-02-2018, 07:41 PM
So it is pretty certain that the shield in wheelhops photos is an Ansen?
Mine looks very close except it has a notch in the edge that is die-stamped at about the 10 o'clock position and mine is from the late 60's so no "Hecho". Any idea what the notch was for?
Mine does clear a 168 tooth flywheel.
Other than that it looks about identical. It has the two flat areas with the two holes near the trans mounting area. I was told they are for an early style frame mount system?
Owned since 1978 - First Car
Old 09-02-2018, 08:12 PM
John Brown's Avatar
The 10 o'clock notch sounds like it may have been to clear a bolt on bracket that supported the inner end of a clutch cross shaft. Bolt on brackets were used in about the same time frame as the bolt on motor mounts that the holes in the lower bellhousing area you mentioned earlier were used. Is there a spot adjacent to that 10 o'clock notch that looks flat where a bracket might have been positioned?
John Brown
Old 09-03-2018, 02:17 AM
Wow, that's cool. Thanks for the I.D. help and the catalog and pictures!
Old 09-05-2018, 10:00 AM
ban617 ban617 is offline
Does anyone know how thick the block plate is , I was thinking it is supposed to be an 1/8” thick ?
Thanks
